Dell V3450 no power from adapter, Battery ok.
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Hi there, Please help me about this topics.
    Its dell vostro 3450. Power from battery ok but it not run from adapter.
    Its PL9 and Pl10 have no voltage when charger connected.
    I replaced isl6237 instead of RT8206B.
    Only Isl6237 LDO 5V out. But no 3.3v and 5v.
    ISL6237
    pin14=0v
    pin27=4.9V.
    output coil 0v.
    Please help for whats wrong.
    attached schematic here.
    Thanks advance.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Dell V3450 no power from adapter, Battery ok.
    do u have signal for EN1 and EN2?
    • nazrul145
      • Jan 2014
      • 337
      • BD
      pu5 on1 0v and on2 4.9V
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Tested the adapter? with a load?
        • alihomee
          • Dec 2012
          • 1591
          • malaysia
          hi bro plz change charging chip then will be ok i think 8731AE they use for this model
          • nazrul145
            • Jan 2014
            • 337
            • BD
            thanks alihomee, ist charging chip isl88731c and i already change it, no power.
            • Ramee
              • Jul 2014
              • 218
              • Israel
              agreed with selldoor..
              Check a/c adapter, but load it up, see if the voltage drop.
              • nazrul145
                • Jan 2014
                • 337
                • BD
                i already check different ac adapter.
                problem with ac adapter 5v enable voltage not come from sio, i mean alwon# so that 3.3v and 5v not come to coil.
                • whaldsz
                  • Apr 2013
                  • 395
                  • Philippines
                  what do you get at pin 13 of PU1?
                  • BCConnectionLLC
                    • May 2015
                    • 47
                    If you get voltage out on PL3 then no need to check the ACOK pin. If ACOK isnt there the chip wont output the voltage.
                    Always check the main output of the chip before going pin to pin.
                    • nazrul145
                      • Jan 2014
                      • 337
                      • BD
                      PU1 pin 13=3.1V, ACAV_IN signal should go SIO IT8518e pin no 21. But SIO Pin21 is 0V.
                      • BCConnectionLLC
                        • May 2015
                        • 47
                        Seems in the diagram there is a diode on that line. Check to make sure its not faulty
                        • nazrul145
                          • Jan 2014
                          • 337
                          • BD
                          it seems good. also replaced it.
                          • BCConnectionLLC
                            • May 2015
                            • 47
                            Do you have continuity to the diode?
                            Only other thing on the line is the pull up resistor
                            • nazrul145
                              • Jan 2014
                              • 337
                              • BD
                              diode is ok, and this resistor place is blank.
                              • BCConnectionLLC
                                • May 2015
                                • 47
                                So going from pin 13 of PU1 to the first pin of the diode is there continuity?
                                • Djosla
                                  • Dec 2012
                                  • 246
                                  • Montenegro
                                  Few things to check:
                                  -check voltage dividers (pr25,pr12,pr11) on pins 2 and 22 of pu1,AC in shoud be low on order to have voltage on ACOK
                                  -check current sensing resistors pr10 and pr16,short may block ACOK
                                  -check pq2 transistor and pr17 and pr18 an ACOK line
                                  • nazrul145
                                    • Jan 2014
                                    • 337
                                    • BD
                                    Yes there is continuity and this is 3.1v but another side of diode is 0v. and this side continuity to ground 65ohm.
                                    • whaldsz
                                      • Apr 2013
                                      • 395
                                      • Philippines
                                      Looks like your SIO needs to be changed. lift one side of D4, and check the continuity of pin 21 to ground if it has 65 ohms.
                                      • nazrul145
                                        • Jan 2014
                                        • 337
                                        • BD
                                        whaldsz you are right, D4 one side also 65 ohms, But i replaced SIO also same. I have replace two sio and also same. When I removed SIO, there is no continuity D3 one side to gnd.
                                          DELL XPS 9560 Notebook 15 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9560 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9560 boardview and 9560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9560 Notebook...
                                          09-06-2024, 06:06 AM
                                          09-06-2024, 05:40 AM
                                          DELL XPS 9365 Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9365 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9365 boardview and 9365 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9365 Hybrid...
