Battery not charging on a Toshiba B40
    Hello all, I have this motherboard, model: MR10F-6050A2578201-MB-A02 for a Toshiba B40.
    Problem is I can't charge this battery. Symptoms are:
    1) If I connect battery first and plug power adapter, the charger LED won't light up.
    2) If I plug power adapter first and then connect the battery, the charger LED light up, but it won't charge the battery, even though Windows says it's charging.
    I have replaced BQ24725A twice and the problem still carries over.
    I need help reading its datasheet, since I can't find the schematic for this motherboard.
    Re: Battery not charging on a Toshiba B40
    what voltage you got on BQ24725A ?
    write the voltage on pins
      When I plug power adapter first and then connect battery (LED charger is amber):
      1) 18
      2) 18
      3) 19
      4) 19
      5) 3.3
      6) 2.7
      7) 0.369
      8) 3.3
      9) 3.3
      10) 1.5
      11) 10
      12) 10
      13) 10
      14) 0
      15) 0
      16) 6
      17) 10
      18) 10
      19) 10
      20) 19.25
      But if I connect battery first and the plug the power adapter, all voltages fluctuate. (LED charger if off)
        SOLVED!
        Thanks to dycc: https://www.badcaps.net/forum/showpo...41&postcount=9
        Basically, I noticed PIN 3 and PIN 4 of BQ24725 had 19V (PIN4 must have 6V above PIN3), so I was checking all the mosfets and noticed one had a short, replaced it with a different model same channel (couldn't find same model) and it worked.
          do you have schematic of this mobo ?
          i need it ..
          Thank You
            Need bios plz
              need toshiba satellite pro b40 bios... any one plssssss
                Here is the bios
                  thoshiba satellite pro b40 shutoff wail booting window
                  please send the schematic
