Battery not charging on a Toshiba B40
  • orientalsniper
    • Apr 2013
    • 461
    Hello all, I have this motherboard, model: MR10F-6050A2578201-MB-A02 for a Toshiba B40.
    Problem is I can't charge this battery. Symptoms are:
    1) If I connect battery first and plug power adapter, the charger LED won't light up.
    2) If I plug power adapter first and then connect the battery, the charger LED light up, but it won't charge the battery, even though Windows says it's charging.
    I have replaced BQ24725A twice and the problem still carries over.
    I need help reading its datasheet, since I can't find the schematic for this motherboard.
  • dj_ricoh
    • 2073
    • uk
    Re: Battery not charging on a Toshiba B40
    what voltage you got on BQ24725A ?
    write the voltage on pins
    • orientalsniper
      • Apr 2013
      • 461
      When I plug power adapter first and then connect battery (LED charger is amber):
      1) 18
      2) 18
      3) 19
      4) 19
      5) 3.3
      6) 2.7
      7) 0.369
      8) 3.3
      9) 3.3
      10) 1.5
      11) 10
      12) 10
      13) 10
      14) 0
      15) 0
      16) 6
      17) 10
      18) 10
      19) 10
      20) 19.25
      But if I connect battery first and the plug the power adapter, all voltages fluctuate. (LED charger if off)
      • orientalsniper
        • Apr 2013
        • 461
        SOLVED!
        Thanks to dycc: https://www.badcaps.net/forum/showpo...41&postcount=9
        Basically, I noticed PIN 3 and PIN 4 of BQ24725 had 19V (PIN4 must have 6V above PIN3), so I was checking all the mosfets and noticed one had a short, replaced it with a different model same channel (couldn't find same model) and it worked.
        • Zazaku
          • Dec 2014
          • 16
          • Indonesia
          do you have schematic of this mobo ?
          i need it ..
          Thank You
          • raihan
            • Feb 2016
            • 42
            • Bangladesh
            Need bios plz
            • mashhoodh
              • Feb 2017
              • india
              need toshiba satellite pro b40 bios... any one plssssss
              • thusie80
                • Jun 2011
                • 10
                • Sri Lanka
                Here is the bios
                • razakchokli@gmail.com
                  • Aug 2017
                  • 11
                  • India
                  thoshiba satellite pro b40 shutoff wail booting window
                  please send the schematic
                  • flat-earther
                    how to prevent a connected charger from draining battery when not charging?
                    by flat-earther
                    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                    So the battery is backfeeding the charger and being drained.
                    How can I prevent...
                    08-07-2025, 01:04 PM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                    NVDC charger configuration...
                    11-05-2024, 03:28 PM
                    Bauer tool battery pack charging with a HERCULES charger modification
                    The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                    Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                    05-06-2023, 12:17 PM
                  • serious_electron
                    Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                    by serious_electron
                    Hello Everyone!
                    I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                    06-28-2025, 02:57 PM
