asus a43sj. battery not fully charge.
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    good day to all
    i have repair here unit asus a43s sticker. on bios model unit it is a asus a43sj...
    anyway itry to plug a charger adaptor on old original battery. indicating need to replace a battery. i try to change a good and brandnew but not original. charging then indicating on windows battery mode charging up but stop the indicator.
    also i try again another may be a battery. upsss same as. i wait to order in asus service center new brandnew original battery for this model. now i have. toink... same as a problem. indicating the charging but stop indicate then not fully charge the battery...
    i thinking it is a hardware problem..
    any one can help me how to fix this problem...
    TIA
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Re: asus a43sj. battery not fully charge.
    follow up...please...
    • razenxd
      How can I charge that battery pack?
      by razenxd
      it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
      At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
      Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
      Now, I have noticed a few things.
      The "dead" battery, while connected to charger and NOT Charging will...
      12-05-2024, 06:11 AM
    • ruletero
      Acer a515-43 low battery charge voltage
      by ruletero
      Hi
      Acer A515-43
      LA-H801P
      Fail: Does not charge battery, has low voltaje on connector.
      Laptop didn't want to turn on, only charge led blinked.
      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
      10-24-2022, 02:31 PM
    • dhenion
      Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
      by dhenion
      I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
      The original board was:
      ASUS X510UNR REV 3.0 A
      The replacement board is:
      ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
      It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
      01-30-2024, 01:45 PM
    • Klevjetack
      Charge a L19D3PDA battery externally from the laptop
      by Klevjetack
      Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
      03-05-2024, 07:26 AM
    • Kambi13
      Asus X512F won't hold on battery charge
      by Kambi13
      Hi all, need some help on this matter. Laptop works fine plugged in, battery still has 80% charge and won't go above that value, and as soon I remove power it won't hold on battery charge and turns off.
      Now on Battery + it has 8,37V, which is roughly the rating for the battery pack, but it should be higher. IC Charger is BQ24780S, BATDRV and BATSRC, both measure those 8,37V, but when I probe them they start with 11,53V and drop immediately to 8,37V.
      Checked the battery mosfets both High Side and Low Side (N-Channel) and they seem ok. Even replaced them to be sure. So my best guess...
      04-05-2023, 09:26 AM
