acer aspire 7520 black screen
  • mista
    • Apr 2015
    • 92
    • belgium
    hi everyone i have a problem with acer aspir 7520
    when i turn on the computer everything run but i have a black screen on my computer i test it with an other screen but nothing too on the other
    someone can help?
    someone have schematic for motherboard?
    thanx a lot
  • lefos
    • Nov 2013
    • 321
    • Greece
    Re: acer aspire 7520 black screen
    I think the problem is from the gpu. Also check the chipset.
    If I remember correctly it has a nvidia card right?
    • mista
      • Apr 2015
      • 92
      • belgium
      thanks a lot for the answer please tell how can i check the gpu?
      yes it s a nvdia ?
      and cpu how can i check?
      can i reflash the rom to arrange the problem?
      thanx a lot
      • dj_ricoh
        • 2073
        ofc this is AMD cpu!
        first you do a reflow and after you can change the bios battery if its LOW voltage
        • mista
          • Apr 2015
          • 92
          • belgium
          hi friend dj ricoh thanx a lot for the answer please my english is poor can you explain to me what s the reflow because i didnt understand
          the computer is directly connected to the alimentation so don have battery anymore
          thanx a lot for help
          • mista
            • Apr 2015
            • 92
            • belgium
            ah yes i see just cook it but hown many time? which degree?
            thanx a lot only gpu? thanx a lot
            • dj_ricoh
              • 2073
              Ok.
              If you use oven its like this.
              No plastic no baterry bios no sticker on mobo.
              The board needs to flat . Chip up. Near the heat element.
              Start the oven with open door let it heat up to 80c.
              The close the door and count 8 min.
              Put screws in the screw wholes so it wont touch the metal to move components.
              • mista
                • Apr 2015
                • 92
                • belgium
                ok i will try to cook the cpu has i read thanx a lot for the information dj ricoh and for help
                i will try it
                do you have picture of the cpu to see?
                thanx a lot
                • dj_ricoh
                  • 2073
                  No.
                  Take the cpu out
                  Board only. Empy. No stickers no bios battery no rubbers.
                  Clean empyy board with chipset up level on screws or some cocking foils and dont touch any component because when its hot the solder its liquid and you can move components by mistake
                  • mista
                    • Apr 2015
                    • 92
                    • belgium
                    ah ok i understand only mother board without cpu gpu etc right ?
                    • dj_ricoh
                      • 2073
                      you got separated graphic card?
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        Conventional ovens only get to 230c MAX.... Rarely hit 230c... Non leaded solder will melt at 217c. Just get it done properly and have the GPU reballed
                        • mista
                          • Apr 2015
                          • 92
                          • belgium
                          hi dj recoh i tried to cook only gpu alone but nothing special
                          so now i will try the motherboad without cpu
                          thanx a lot newtothis for the information
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3593
                            • slovakia
                            dude oven is bullshit. board will start to twist=killed
                            u just need halogen light 120W for 5eur, ALfoil, thick paper and multimeter with thermoprobe
                            mista> heat up board under ic to 100c and check for image
                            • dj_ricoh
                              • 2073
                              Aspire 7535 no display.
                              Bios battery was flat
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Even reballing is not the solution, the chipsets are faulty and need replacement. If you heat it up it will last 3 months at most and die again.
                                Yours is the model with nvidia chipsets everywhere. It could be either the GPU or the Northbridge in your case. Not worth repairing, scrap.
                                A working TV? How boring!
                                • mista
                                  • Apr 2015
                                  • 92
                                  • belgium
                                  hi friend th3 un1qu3 do you have a picture about northbridge?
                                  thanx a lot
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    • mista
                                      • Apr 2015
                                      • 92
                                      • belgium
                                      hi friend sorry for tardive response i receive the computer and i took some picture
                                      but i find something strange on gpu and it s a nvidia the strange thing is there is one smd left on gpu check the picture please and all advice are welkom is it maybe the reason tha t i have black screen ....
                                      • itsmeinit
                                        • Apr 2015
                                        • 15
                                        • England
                                        Hi, has anybody ordered from BGA Supplies because i made a order on the 14th and I've still not heard anything, tried to phone them but just get answer machine, starting to think their bogus
