chip capacitor test
  • ranjanlaptop
    • Dec 2013
    • 207
    • india
    chip capacitor test
    how can i check on board chip capacitor leakage or short without removing capacitor.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3574
    • slovakia
    Re: chip capacitor test
    with ESR meter
    • chth96
      by chth96
      03-09-2024, 10:03 PM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
      Common SPI bios chip programming Questions and Answers
      by SMDFlea
      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
      A: If you can`t read from it how do you expect to write to it ?.
      Q: Why is my bios chip unreadable ?.
      A: The programmer is faulty or has a worn or broken zif socket.
      The USB cable is frayed,connector pins worn or some other physical damage.
      Not enough amperage or voltage to power the programmer properly.
      Bad...
      09-02-2021, 04:40 PM
    • ktmmotocross
      laptop onboard memory test and identify bad chip
      by ktmmotocross
      Hello.
      Know somebody how to successfuly test bad onboard memory and maybe even bad chip localization?
      Have newer asus that show memory related BSOD. After reball still the same. how to test if it is some ram chip or maybe bad ball under cpu or even cpu
      07-16-2024, 05:33 AM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
