Dell Latitude E6320 - Completely dead, no {lights,fans,CPU heat}
  • fuxxy
    • 318
    Re: Dell Latitude E6320 - Completely dead, no {lights,fans,CPU heat}
    PU14
    Pin 18 is open in respect to ground.
    Shorted Pin 9 to pin 19
    Tested voltages on PU2 with adapter plugged back in
    Pin 4 - Measured 168.2 mV
    Pin 6 - Measured 19.29V
    Pin 7 - Measured 75 mV
    Pin 14 - Measured 165.7 mV
    Pin 27 - Measured 166.3 mV
    • khaahk
      • Dec 2013
      • 756
      • Estonia
      I think you meant PIN 9 to PIN 18
      The 3.3V from PU2 pin 5 (5mA from datasheet if i remember correctly) might not output enough current for 3.3V ALW. But it is hard to say anything else. If you have a lab powersupply then try to insert 3.3V to pin 19 track and see how much current is drawn. Visual inspection under microscope to find any missing connections if water damage was present.
      • fuxxy
        • 318
        Correct, Pin 9 to pin 18 on PU14.
        I do not have a lab power supply, but I do have some spare ATX. I'll use the 3.3V bus from that and report results.
        • khaahk
          • Dec 2013
          • 756
          • Estonia
          You can't control current with atx psu, so be careful...
          • fuxxy
            • 318
            Applied +3.3v and ground from an external 3.3v source. Verified source was putting 3.3V.
            PJP50 (+3.3V_ALW) is now 3.27V
            PJP48 (+5V_ALW) is now 2.74V
            PJP49 (+15V_ALW) is now 1.81V
            PU2 pins
            Pin 4 - Measured 0.263V
            Pin 7 - Measured 1.678V
            Pin 14 - Measured 0.263V
            Pin 27 - Measured 0.263V
            • khaahk
              • Dec 2013
              • 756
              • Estonia
              #26
              Guess that some things must remain a mystery.
              • thestigp11gt
                • Jun 2013
                • 30
                • Scotland
                #27
                Hi guys, I hope it is OK to hijack this thread.
                I saved an E6320 from the scrap heap, Story it was -put in a docking station, and killed the laptop (We know if was a docking station as someone managed to kill 2 other laptops the same way).
                Anyways the battery wont charge pretty much the same as the title. I did narrow down to a SMSC MEC 5055 LZY chip getting very hot when plugged into the mains, Also there is a scorch mark and even melted a bit plastic from a wire onto it.
                Now basically could this still be a short or is it pretty much that chip is cooked?
                There is 2 MEC 5055 chips next to each other, its the left side one that seems fryed.
                • diamon
                  Dell Latitude 5520 completely dead
                  by diamon
                  I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
                  Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
                  After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
                  Have checked with a thermal camera, and there are a couple of things...
                  03-05-2025, 02:23 PM
                • wangbreeze
                  T480s random shutoff and then completely dead
                  by wangbreeze
                  Hello Gurus,
                  I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                  I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                  Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                  charger gave - 20V - ok
                  U101B
                  02-03-2024, 04:57 PM
                  Dell Latitude E6320 Schematic
                  Dell Latitude E6320 Compal LA-6611P Schematic...
                  10-04-2024, 07:50 AM
                • pavski
                  Completely dead MSI z490 tomahawk
                  by pavski
                  Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                  I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                  t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                  Can you please let me know if this is indeed incorrect and what else should I look at next?
                  Thanks!
                  06-02-2024, 02:42 PM
                • YellowJacket
                  DELL Latitude 5410 - dead; pwrbtn flashing
                  by YellowJacket
                  Hi folks,
                  DELL Latitude 5410, board number FDZ41 LA-J371P Rev: 1.0 (A00), schematic uploaded in different post, here is the link --> https://www.badcaps.net/filedata/fetch?id=3484415
                  When I connect it to a power ( DELL round charger, or USB-C ), LED on the power button starts flashing white, and the laptop doesn't do anything ( flashing slows for a very brief time in time when I press it, but it continues again ). Battery is not charging. While the charger is connected, I have few voltages present, but some of them are fluctuating, see attached pictures.
                  All I was able...
                  04-26-2025, 07:05 AM
