MacBook a 1181 k36c no power no led magsafe
  • inspirim
    • May 2013
    • 282
    • Italy
    This notebook does not turn, turns on only when it is held down the power button and inserting the connector magsafe with the fan running at full, the LED does not light magsafe, no green light, no light orange charging, replaced U7000 ISL6258 but without result, the voltage on the fuse F7000 good, good tension of 3,425 U6990
    you have any idea
    thanks to all
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3595
    • slovakia
    Re: MacBook a 1181 k36c no power no led magsafe
    what is voltages on u6990 and on charger without starting
    • inspirim
      • May 2013
      • 282
      • Italy
      3.38 volt output of U6990, the notebook starts normally with the battery but is not charging
      thanks
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3595
        • slovakia
        but output must be 3.425
        remove ic and inject 3.425 to see if charger lights up
        • inspirim
          • May 2013
          • 282
          • Italy
          I tried removing ic given 3,425 volts but the charger does not light
          thank you
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            pin voltage of u7000 ?
            • inspirim
              • May 2013
              • 282
              • Italy
              thanks for the time that you're paying, on which pin of U7000 want to know the voltage?
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                all 28
                • inspirim
                  • May 2013
                  • 282
                  • Italy
                  it is normal that the pin 14 AC CHGR_ACOK have zero volts?
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3595
                    • slovakia
                    ofcourse not. acok is charger signal that tells charger voltage is ok
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      that voltage comes from smc.
                      check in your schematic for SMC_BC_ACOK and trace it . ull find a resistor. check voltage before and after. if needed replace resistor. if resistor is ok,check the onewire circuit. and try to see if SMC_BC_ACOK is ok here too. if not,... it's a smc problem. try reset smc by holding power botton 10 seconds (without any power source) and if tht doesnt work could be bad solder or smc need to be replaced.
                      • envym
                        MacBook Pro 2018 with Activation Lock
                        by envym
                        Hi everyone!
                        I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                        I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                        06-27-2025, 08:54 AM
                        MagSafe Audio Board MacBook Pro 15" A1226 Left I/O 820-2102 Boardview
                        MagSafe Audio Board MacBook Pro 15" A1226 Left I/O 820-2102 Boardview...
                        10-28-2024, 03:29 AM
                      • shivahoj
                        Macbook A1297 Mid2010 820-2361a Magsafe schematic?
                        by shivahoj
                        Hello, the Magsafe connector of the above Macbook was defective(burnt pins). It is located on a small DC-IN board labeled 820-2361a sitting in the top right corner of the macbook, connected to the main PCB with 5 separate cables.
                        While replacing the magsafe, I must have unsoldered and lost a small SMD Resistor that is silkscreen-labeled R1 on the solder side(opposite of the magsafe and ferrite filter). It carries the 1bit-bus to the Amber/green LED driver chip in the Magsafe plug, and without connection to the 1-bit chip in the plug, the macbook won't charge.
                        ¿Can anyone please provide...
                        12-31-2020, 08:13 AM
                      • paparazzo79
                        Charging macbook pro mid 2014 15" with magsafe 2 60W charger
                        by paparazzo79
                        Hi guys.
                        May I charge this model with 60 W charger?
                        I know it requires 80 W to charge, but don't want to buy one.
                        If it specifically requires and 60 W can damage macbook and vise versa, I guess I will have to buy 80 W one....
                        09-28-2024, 02:47 AM
                      • tobeend
                        Bypass mdm macbook m2 ventura
                        by tobeend
                        1. RESET MACOS WITH IPSW
                        a. Power off MacBook, press and hold the power button to enter Recovery
                        b. Open Disk Utility, remove Macintosh HD
                        c. Reboot, connect to the network to Activate Mac.
                        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                        e. Release the other keys, but keep holding the Power key for another 10 seconds
                        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                        05-26-2023, 07:18 AM
