nvidia ic undervoltage
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3616
    • slovakia
    everybody know that voltage regulator for nvidia ic can be hw modded. unique release even calculator for that.
    i look in my bios folder and found NiBiTor for modding nvidia bios and it have even frequency and voltage modding feature. do u think that it can be used to undervoltage nvidia ic without hw regulator modding?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: nvidia ic undervoltage
    BIOS mods can only be used when there is hardware support for it. You have to check the schematic. I have successfully used this on a gaming laptop i have recently bought (oh yeah, i have to remember to actually post about it). This one was actually in the other direction - the chip is fine and doesn't have a problem with heat, but it became unstable in "power saver" mode due to core voltage being too low in that state. So i set all states to use the 3D mode voltage of 1.0v, and the laptop has been running great since.
    However, there are many boards that will only show you different voltages in the different performance states of the chip - in hardware, the voltage really stays at the same level all the time.
    Also, most nvidia chips can go lower in 3D mode than even the "low" level that is factory set. There will be at most two voltage values, one "low" and one "high". There are some boards which have digital VRMs, but you will find that even for those, the values are hardcoded either in the BIOS or the EC, and there is no obvious way to change them (i've tried). And the nvidias need all the help they can get to live a long life. So while a BIOS-level modification is possible on some boards, it is no match for a hardware mod.
    Besides, BIOS modding on laptops is quite tough. You have to first get (or dump from the machine) a clean ROM file. Then you need a way to extract the video BIOS module from it, edit it, then put it back in there without messing anything else. There are plenty of tools for Phoenix BIOS, but others like Dell or Insyde, not so much.
    A working TV? How boring!
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3616
      • slovakia
      so using regulator hw mod is easyest and safest way?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Yes. Since you have the laptop apart for repair anyway, might as well change one resistor and do the undervoltage mod too.
          by Vesko356
          08-11-2023, 03:27 AM
        • piernov
          NVidia bumpgate
          by piernov
          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
          May complete this post at a later date with more details.
          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
          03-27-2021, 10:34 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
