HP Pavillion G6
  • tonydix
    • Dec 2013
    • 31
    • Panama
    HP Pavillion G6
    No lights, no power on light, no start
    Stripped whole unit down and tried power supply with bare mboard.
    Power supply shuts down when jack is inserted.
    Clearly a short on the mboard somewhere.
    Any ideas gratefully recd. Thanks Tony
  • Agent24
    I see dead caps
    • Oct 2007
    • 5069
    • New Zealand
    Re: HP Pavillion G6
    You should probably start with narrowing down which area the short is. Which side of the power management IC for example?
    Do you have a schematic? If so, post it here so we can look at it as well, if not, post full motherboard code and hopefully someone can find one
    -David VanHorn
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      Re: HP Pavillion G6
      First measure the ohm on power jack, Try to iniect a 1 amp 3 volt (start low and increase carefully) on power jack and look if a component become hot.
      if you post the exact mobo model I post the schematic.
      In some cases the short is on capacitor or mosfet but if is on another chip is more difficult to detect because you must separate various circuit on motherboard like dc/dc 3v 5v and so on.
      try to detect current consumption on
      • tonydix
        • Dec 2013
        • 31
        • Panama
        Re: HP Pavillion G6
        Model HP Pavillion G6
        ICC s/n RR18B117BT
        SPS 6949288-001
        Date Code CS1184
        Hope this helps
        • reaper57
          • Sep 2014
          • 216
          • Norway
          Re: HP Pavillion G6
          Good pictures of both sides of the motherboard would be great. A more detailed picture of the area around the power plug is also going to be useful.
          Keyboard not detected, press F1 to continue...
          • jasko_jacker
            • Oct 2014
            • 1140
            • italy
            Re: HP Pavillion G6
            For a schematic I need a G6 model or motherboard code or spec because there are many model of g6, or post a pics .
            Have you a adjustable power supply in current and voltage ?
            • aanan
              • 222
              • India
              Re: HP Pavillion G6
              check this.
              • reaper57
                • Sep 2014
                • 216
                • Norway
                Re: HP Pavillion G6
                I'm pretty sure that there is a shorted mosfet somewhere around the power plug, but I'm just not very good with schematics. That's why I am asking about photos.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5069
                  • New Zealand
                  Re: HP Pavillion G6
                  Page 37 shows the DC jack and management circuitry, if that's the correct schematic.
                  -David VanHorn
                  • tonydix
                    • Dec 2013
                    • 31
                    • Panama
                    Re: HP Pavillion G6
                    Here is a picture of the mboard. The numbers are 6050A2412801.
                    The schematics suggested above do not seem to apply. Searching for 6050A2412801 on this site suggest the mboard may be Invatec Rocky AMD rather than Quantum. Niether has the power connector labled as CN12 as on the board. I am puzzled !!
                    Thanks for all the help
                    Tony
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5069
                      • New Zealand
                      Re: HP Pavillion G6
                      Your link doesn't work. Please upload photos to the forum along with your post, it makes it easier.
                      Info here: https://www.badcaps.net/forum/showthread.php?t=1868
                      -David VanHorn
                      • trebo
                        • 514
                        • Wales, UK
                        Re: HP Pavillion G6
                        the link don't work for me either if I double click the left button
                        but if I right click the link once, then left click on (open link), It opens the link
                        • tonydix
                          • Dec 2013
                          • 31
                          • Panama
                          Re: HP Pavillion G6
                          I have tried again is this better ?
                          Tony
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5069
                            • New Zealand
                            Re: HP Pavillion G6
                            Great but unfortunately I don't think that sticker is what we need...
                            The numbers required should be silkscreened on the board (the fine white lettering) somewhere. If you can't find anything obvious, try uploading a photo of the whole board, both sides. It may even be under the sticker itself.
                            I could be wrong, but Q60 in the top left of the board looks like it may have a hole blown in it. It could well be just the manufacturer mark too, but it seems a little 'off'. Can you inspect it more carefully and check?
                            -David VanHorn
                            • tonydix
                              • Dec 2013
                              • 31
                              • Panama
                              Re: HP Pavillion G6
                              The silkscreen numbers are :-
                              6050A2412801.
                              MB-A02
                              2011-04-29
                              HSTNN-I94C
                              The schematics suggested above do not seem to apply. Searching for 6050A2412801 on this site suggest the mboard may be Invatec Rocky AMD rather than Quantum. Neither has the power connector labled as CN12 as on the board. I am puzzled !!
                              Tony
                              • atsio
                                • Oct 2013
                                • 819
                                • Greece
                                Re: HP Pavillion G6
                                Try those
                                • tonydix
                                  • Dec 2013
                                  • 31
                                  • Panama
                                  Re: HP Pavillion G6
                                  Sadly no joy those schematics do not reflect the board I have. But thanks everyone for trying.
                                  Tony
