Hi. Can someone post BIOS for HP Pavillion 17-g140nm? Any clean version will be fine. I have laptop with dead BIOS and need to flash. Thank you!
HP Pavillion 17-g140nm BIOS request
post the contents of the bios chip even if it is corrupted..
read the forum rules..https://www.badcaps.net/forum/troubl...ore-posting -
Sorry for the bad post. Here is requested:
HP Pavilion 17-g140nm
Prod ID: T1M78EA#BED
S/N: 5CD6114JMF
Motherboard:
MODEL:X1BD
DAX1BDMB6F0 REV:FAttached FilesComment
I did check, they are all good.Comment
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
Channel: BIOS Requests ONLY!
by Dzhuza21Hello,
I have an HP EliteBook 840 G6 with the following details:- PROD ID: 4WG30AV
- Serial Number: 5CGO28HLD
- Motherboard model and revision: currently unknown, as I have not disassembled the laptop.
The laptop does not power on due to what I believe is a BIOS issue. I am looking for the two BIOS files for this model, approximately 16 MB and 32 MB, to reflash the BIOS chip directly using a programmer.
I have already checked the official sources and several forums but could not find these files for free. If anyone could provide these BIOS files or guide me to...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
- Loading...
