Power Problem [can't resolve, plz help]
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: Power Problem [can't resolve, plz help]
    I injected 2v 3amp to the ground pad of PL5, ICH goes extreme hot within seconds. No other parts are hot.
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      PL5 get hot ???
      dj_ricoh it helped me out tons of times
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • Duranitron
        Asus x512dk rev 2.1 power on problem
        by Duranitron
        When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
        Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
        11-26-2024, 10:22 PM
      • EazyBone
        LG OLED55C9PUA power problem
        by EazyBone
        Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
        Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
        I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
        The power supply to t con is different story.
        This...
        06-23-2023, 07:43 AM
      • Dr.d
        Help please..Lenovo ideapad 5 14itl05 power and charging problem
        by Dr.d
        I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
        Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
        04-05-2024, 11:48 AM
        by sam_sam_sam
        03-31-2024, 02:12 PM
