Internal power supply problem HP dv6-1160eg
  • decsystem20
    • Oct 2014
    Hello Everybody,
    I have a problem with my HP Laptop.
    The Model #: dv6-1160eg
    The Motherboard Reads:
    HannStar J MV-4
    94V-0 0828
    A Schematic of the board is available.
    The problem is as follows:
    - The machine was shut down properly, afterwards the plug of the external power supply was pulled.
    - The next morning the power supply was connected to the wall outlet.
    - The LED next to the plug on the laptop was flashing slow.
    - The external power supply was checked for proper voltage The output was around 19V.
    - Two other power supplies were tried with the same result, flashing LED near the plug.
    - After dismantling the unit the voltage was checked at the connector on the PCB.
    It changed between 0 and around 2-4 Volts.
    I need help as to where to start looking for bad parts.
    My first guess would be bad MOSFETS, but which one to check first?
    If the FETs are bad, is it possible that there are other parts that go bad when the FETs die?
    All help is greatly appreciated.
    Regards,
    Decsystem20
  • khaahk
    • Dec 2013
    • 810
    • Estonia
    Re: Internal power supply problem HP dv6-1160eg
    Resistance on pq48 pin3 to gnd? Resistance to gnd on big coils? Lab supply to find short circuit...
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
