Toshiba C850 burned component ID?
  • sparker1
    • Sep 2011
    • 343
    Hello, I have a toshiba C850 (MB PLF/PLR/CSF UMA REV 1.1). It had a shorted buck controller that I will replace but there is another component that I can't identify that had got very hot and splattered solder here and there. It looks to be a transistor. The best I can make of the markings is "2150j". I don't have a schematic (the only one I could find here on Badcaps was not the same one). Is anybody able to identify this item? I've googled without luck. Hardly any of the components are labelled on the MB. I've also checked all my scrap boards to try and find the same IC but no luck. Some photos attached. Grateful for any help.
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: Toshiba C850 burned component ID?
    Here are 3 more schematics
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3582
      • slovakia
      looks like some kind of power switch to that connector. so it may be transistor. but why its contacts bridged?
      what component is connected by this connector?
      • sparker1
        • Sep 2011
        • 343
        Thanks Cyberhack for your effort but no cigar I'm afraid.
        • sparker1
          • Sep 2011
          • 343
          The connector adjacent to it is for the mouse button FFC connector. As to why is it bridged? I am confused to. All this happenned before I bought the laptop. I've got a bad feeling that the bridge is actually a trace wire from the motherboard that has been caught up in the drama. It was also bridged to the inductor nearby by solder flowing to it whenever the damage ocurred.
          This is an expensive board to buy too, drat.
          • khaahk
            • Dec 2013
            • 760
            • Estonia
            Check for similarities on similar mainboards. Here is snapshot from another inventec mainboard. I think somebody has changed the sot23 already. The component is most likely similar on many mainboards. Is the 3rd leg connected to gnd and another two to clk and data?
            https://cdn.badcaps-static.com/pdfs/...7453b0adbb.pdf
            • rievax_60
              • May 2012
              • 897
              • australia
              To make the markings easier to read, I clean the part with turps usually. Then run a white pen over it, then lightly wipe the ink off, trying to leave the ink in the laser grooves.
              • sparker1
                • Sep 2011
                • 343
                Thank you very much. Yes the connections are exactly what you said. I might try one from another scrap board when the buck controller arrives.
                • sparker1
                  • Sep 2011
                  • 343
                  Hi Rievax. The damn thing fell on the floor never to be found again for all eternity. Khaahk's advice will help me though. Identification of components is often a problem for me so I'll remember this tip for future use.
                  • 36views
                    • Feb 2012
                    @sparker1
                    probably too late but i also read 2150j (very small 0) on my board which is a rev 2.1 of that motherboard model.
                    if you want me to test that component i could probably check some pn junctions but in circuit you can't always be sure of the results..
                    i've got a "dead" c850 with that board, did you manage to find a schematic for it ?
                    it's not the inventec dakar dk10 available in many places.
                    • kodox
                      Toshiba Portege Z30-A - Burned Chip Identify
                      by kodox
                      received unit with no power at all, pluged bench PSU and not consuming any amperage, measurement shows that 19V only reaching first mosfet & gate voltage only 6V.
                      visual inspection found that it has burned chip, marking code wasn't too clear under microscope, i guess it's "A C C I". the chip is located under huge diode with UCQ1QA03 marking on it, since i don't find any schematic or boardview for this model, wandering that someone had similiar board and kindly measure what voltage comeout from the inductor connected to that chip or maybe knew what model number of the chip...
                      09-15-2023, 09:38 PM
                      09-06-2024, 05:27 AM
                      09-06-2024, 05:59 AM
