Pchub.com
  • tw2005
    • Oct 2011
    • 6458
    Pchub.com
    Quick question. Anyone dealt with or heard of PCHUB?
    http://www.pchub.com/uph/
    Thinking of purchasing a Toshiba screen fascia and mask for A500.
    just want to be sure they're legit.
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Pchub.com
    there was a time when they were cheap, but on ebay, i find more component cheapter (for most used laptop), maybe if u cant find what u look on ebay , or alibaba, or aliexpress (if trustable) then pchub would be ok. always looked that site, but never bought anything from them till now
    • tw2005
      • Oct 2011
      • 6458
      Re: Pchub.com
      What they have I need and good price. Can't find anywhere, not easy or cheap.
      So you have purchased from them recently?
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        Re: Pchub.com
        never purchased from them, but watch that site from many years to look for part number
        let's wait for someone that bought from them
        • myth77
          UV solder mask - high temp resistent, recomendation?
          by myth77
          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
          Is there any solder mask...
          03-28-2022, 04:04 AM
        • rawnq
          Satellite A500 LA-4991P UMA Conversion Help Needed
          by rawnq
          hi all , this my first post here
          long story short my friend give me a dead a500 board with multi faults and without mxm graphics card
          after changing EC , CPU core driver , 3.3v 5v power supply , and some work i got the board working again
          so i decided to convert from discrete to UMA and start this little project , so far i managed to only reroute LVDS signals , clocks , power to use the gm450 internal graphics
          still more work to CRT , HDMI but for now i tested and got stuck and i need a hand to solve this problem
          with original A500...
          10-20-2024, 11:30 AM
        • nubinator
          Tape mask on samsung RU7100
          by nubinator
          I got boot looping 65RU7100 and did tape mask and got image back. I narrowed down the problem to 1 pin it was pin 16 on left side which is CKVB1 so I masked that pin as well as CKV1 cause I read should do them in pairs. Image is pretty good but I get horizontal scan lines on bad side of panel, any way to fix this? When I was experiementing with blocking CKV pins I noticed the more I blocked the more color loss I got on bad side of panel
          05-21-2025, 06:49 AM
        • rawnq
          satellite A500 LA-4991P bios
          by rawnq
          hi i need satellite A500 board LA-4991P bios
          thanks
          10-21-2024, 05:43 PM
          Acer Iconia A500 Tablet Schematic
          LA-6871P...
          10-21-2024, 05:06 AM
