Toshiba U920T dead, water damage
  • dj_ricoh
    • 2073
    Re: Toshiba U920T dead, water damage
    My guess is that the mosfet that output the voltage foe battery recieve only 8v on gate and result it output 8v . To find the problem i thing you nees to find why is 8v to gate
    • grahamw01
      • 256
      Hi, thank you, I may be wrong about the 8V, I checked all the fets and there is no voltage on any pins on all 4 when the orange LED is on to say charging. Do you know what the attached chip is? it says 39A303B but I cant find anything on google for this. Pin 1 of this is heavily corroded which is 19V. Most the pins do have a few voltages on them, around 2V to 5V. Could this be the charge controller?
      • dj_ricoh
        • 2073
        do you see that the pin1 has no pin and leg
        • grahamw01
          • 256
          yea, this chip has no pins though, it has pads that go underneath. Is this chip for charging control, like U6000 on the L855? I would assume if this was broken then the laptop would not work at all, but it works fine just not charing
          • dj_ricoh
            • 2073
            you got problems there!
            i know its a QFN chip but it needs to go to that cap!
            if its pin maybe its 19v what voltage do you got on the cap?
            • grahamw01
              • 256
              yes the cap is 19V. I thought maybe the 19V is connecting because lots of the other pins have 2V-5V on them
              • dj_ricoh
                • 2073
                #27
                you need to be 100% sure you got 19 v there.
                For this type of repair i suggest a microscope.
                Cheap one.
                You need to see the solder near qfn chip.
                The pin1 its not the only one with problem what i saw in the pic.
                • grahamw01
                  • 256
                  I am going to remove it and try to resolder it, but I am not sure if this is even to do with charging. If it isn't for charging then it must be okay all ready since the laptop works fine otherwise. I wish I could find out what "39A303B" does
                  • dj_ricoh
                    • 2073
                    #29
                    then don`t touch it!
                    if you can re solder it much better go for it
                    • grahamw01
                      • 256
                      Hi again,
                      Recently I removed this chip, cleaned the pads and put it back on and it seemed to work. 13V going to the battery and it was charging, but after 1 hour the chip over heated a died, I guess it shorted. I was wrong about the model of this chip, it is a Fujitsu 39A404B (MB39A404B) I can find on ebay 39A404 and 39A404A but no 39A404B anywhere, will one of these be compatible?
                      thanks!
                      • m_anwar_55
                        • Jun 2015
                        • qatar
                        #31
                        hello
                        I have the same problem with my U920T it's dead and require this ship and I can't find it also . is there any advise please
                        • ianbak
                          Toshiba R940 with water damage
                          by ianbak
                          I have a Toshiba R940 which doesn't power on (fully) due to liquid damage. The mother boards is FAM2SY2 A2356A.
                          Most of the corrosion has cleaned up well, although I can see a few joints that need touching up. More troubling is the fact that one of the components appears to have been eaten off the board. You can see it if you zoom into the attached photograph, and it is clearly missing in the close up view.
                          I can't find a schematic for this motherboard, and wondered if anyone had any ideas about identifying the missing component?...
                          04-16-2025, 06:20 AM
                        • Ugur87
                          MacBook Air M4 A3240 Brand New Water Damage no Image
                          by Ugur87
                          I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                          Yesterday, 01:09 PM
                        • edugimeno
                          Stagg sms12p audio amp has water damage
                          by edugimeno
                          Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                          I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                          There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                          There is only one signal wire connecting the first boards...
                          05-24-2025, 06:00 AM
                          09-06-2024, 05:27 AM
                        • darckreign1984
                          HP 1040 G3 water damage, keyboard and touchpad dead
                          by darckreign1984
                          If I press numlock on external keyboard, the led from internal keyboard light up for a short period of time.
                          any advice?
                          DA0Y0FMBAJ1 REV J
                          MODEL Y0F...
                          03-01-2024, 09:24 AM
