Toshiba R940 with water damage
  • ianbak
    • Apr 2023
    • 55
    I have a Toshiba R940 which doesn't power on (fully) due to liquid damage. The mother boards is FAM2SY2 A2356A.
    Most of the corrosion has cleaned up well, although I can see a few joints that need touching up. More troubling is the fact that one of the components appears to have been eaten off the board. You can see it if you zoom into the attached photograph, and it is clearly missing in the close up view.
    I can't find a schematic for this motherboard, and wondered if anyone had any ideas about identifying the missing component?
  • cappernicus
    • Sep 2024
    • 19
    It is a 100ohm resistor. I have the r945, but they appear to be the same board. As a sanity check, the one below it is a 1k.
    I don't know if you still need it or not, but I hope this helps.
    • ianbak
      • Apr 2023
      • 55
      Hi Cappernicus,
      Thanks so much for that! I didn't get a notification so I've only just seen your reply. I'll replace it and see if things improve!
      • Ugur87
        MacBook Air M4 A3240 Brand New Water Damage no Image
        by Ugur87
        I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
        08-28-2025, 01:09 PM
      • edugimeno
        Stagg sms12p audio amp has water damage
        by edugimeno
        Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
        I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
        There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
        There is only one signal wire connecting the first boards...
        05-24-2025, 06:00 AM
        09-06-2024, 05:27 AM
      • RetroComputingGrotto
        Water Damaged Toshiba 48L1435DB
        by RetroComputingGrotto
        I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
        The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
        10-07-2024, 08:23 AM
        09-06-2024, 05:59 AM
