MBX-235 cannot shutdown
  • orientalsniper
    • Apr 2013
    • 459
    Hello, this computer returned from this problem: https://www.badcaps.net/forum/showthread.php?t=40029
    I can shut it down manually (holding power button), but when I shut it down via Windows, all power goes off and then comes back on.
    What I've tried: replacing battery charger IC, removed modem, removed card reader IC, turning off from a Live Linux USB.
    EDIT: It won't go to sleep either, it will come back on instantly.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3607
    • slovakia
    Re: MBX-235 cannot shutdown
    check this thread
    https://www.badcaps.net/forum/showthread.php?t=40568
    • orientalsniper
      • Apr 2013
      • 459
      Yeah, I used to have an issue similar to his in a Toshiba where the multimedia panel was shorted, however before I shutdown this Sony, I unplugged the media/power panel and no dice.
      However, it turns off fine now..... SMH
      • xxxvirus1987xxx
        unlegendary
        • Sep 2014
        • 24
        • philippines
        are the power button working normal...maybe shorted micro switch....
        try to clean the buttons and some cables etc....
        • cruiser_
          A1466 820-00165 intermittent shutdown
          by cruiser_
          hi there,
          Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
          Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
          Gives shutdown cause -128.
          Seem to work fine in SMC bypass.
          Same shutdown happens with disconnected TP/KB/KBLED/CAM.
          Observations:
          - SMC_RESET_L - when pulled down - plug goes orange/green and...
          10-11-2022, 12:06 PM
        • cappernicus
          Satellite r945-p440 - Hard crash coming out of sleep
          by cappernicus
          Toshiba Satellite r945-p440
          Motherboard: FAM2SY2 A3256A
          I do not have a schematic or board file
          I usually let it go to sleep every time I use it because it is nearly always plugged in, with occasional shutdowns to reset things. Then it started to hard crash every time it tried to come out of sleep. The lights would come on for half a second but before anything shows on the screen they would all shut off and it would boot up as if I had shut it down completely (except that windows knows it didn't), and when it comes back on the fan ramps up to full and stays there perpetually...
          04-16-2025, 05:31 PM
        • RATIM SIDDIQUE
          hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
          by RATIM SIDDIQUE
          automatic shutdown after 30 sec of display coming
          do not shutdown without ramstick
          someone give me idea plz
          08-20-2024, 03:50 AM
        • howardc64
          P502UI-B1E shutdown automatically after 75s followed by power light blinking 15x
          by howardc64
          History
          - Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
          - I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
          - Fixed 2 circa 2015 Vizios before with classical main board...
          11-28-2020, 04:25 PM
        • mosfetratus
          macbook A2918, orange light off when shut off
          by mosfetratus
          When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
          Works with battery and charges, but when i shut off i get this problem.
          It had liquid spill. Board has no corrosion, keyboard is working, power button...
          05-31-2024, 03:34 AM
