Battery from 70% to off
  • ziko07
    • Jun 2021
    • 102
    • Somewhere
    Hi, I have 2 laptops ,yoga 11e and dell ,both 12" screen. Especially dell have problem, when I full charge battery and use on battery after that (next days also) laptop can works 3-4 hours.
    But if I switch off by windows power off not standby or hibernate and not touch laptops 15-20 days, I power on battery level is ~ 70% and after 1-2 goes to zero. I know battery is probably problem but how discharge if is OFF, and know that laptop is nevervoff,has +3v,+5v always, but still battery discharge almost all capacity.
    Tnx
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • mkdj
    ASUS X571 no power : battery issue?
    by mkdj
    Mark and model: ASUS X571
    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
    Tests already made:
    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
    - I have removed...
    07-14-2025, 09:16 AM
  • techfreak9356
    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
    by techfreak9356
    I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
    09-14-2023, 11:10 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • ferah831208
    Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
    by ferah831208
    Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
    03-18-2025, 01:18 AM
