LG R380 no power randomly EBR63567605 motherboard
    Hey guys,
    I got this laptop atfer the owner gave up on it..
    I bought it for 50$
    The keyboad and both hinges were replaced just now.
    Battery is dead though...
    This laptop suffered from water damage..
    The problem happens on randomly,
    The charging light appears after a sec after plugging in the charger.
    I have a 3.3v on power switch.
    When i press the power button the laptop tries to power on for a milisec then fails and the charging light apears again.
    sometimes (rare) it powers on just fine.
    I opened it up and cleaned the corrosion on some parts the pad just been eaten.
    Do you think it is possible to fix it or shall i try to find a used board or just sell it for parts.
    Re: LG R380 no power randomly EBR63567605 motherboard
    Does anyone has the schematics for this board..
    i need some troubleshooting ideas on how to approach this kind of fault.
    thanks
      Soap and water wash it
      If you have ultrasonic bath then use that with Ultrasonic Cleaners
        cyberhack, i already tried my best with alcohol and a toothbrush.
        i think i need to fix those 3 bad components that the pads got eaten..
        i dont know what they are caps/coils? and their ratings.
          I gave up on the old mainboard,
          I orderd a used one from ebay,
          The laptop is starting normally again.
          i have one issue, i can't remember the wifi antenas digram...
          i have 4 wires: 2 whites, 2 blacks.
          i have 2 wifi cards, i guess one is a 3G modem or something..
          could you guide me which goes where? does it even matter?
            that ol board works fine, just resolder that components. no need to change
              You didn't understandme im sorry,
              The whole laaptop works i don't need to soldier anything.
              i need to plug in the antenas cable to the wifi and modem cards.
              the problem is i can't remember which goes where....
                Bad luck with this laptop,
                after a few months that it worked great,
                the mainboard i replaced died too :-)
                i want to try and get 1 board working out of 2 bad ones.
                need some help on no power symptom..
                i already tested the dc jack,
                i got 19vdc on 2 fets..
                anything else you would recommend?
                  you can try the bios, reprogrammer the bios chip.
                  The Night Drop Down, I Will Keep Try Until..., You Never know.
                  Dushi Kòrsou, Nos Tei.
                    I never did find out how to do i now if its a bios fault?
                    After plugging in the AC adapter, i don't get the charger light,
                    only after a few seconds or minutes (randomly) i have light and i manage to power it on.
                    Very strange...
                      if the charger is ok, it can be the bios, if bios fault laptop won't start.
                        Any recommended programmer i can test the bios with?
