Dell XPS L720x turns off the charger
  • eoegbero
    • May 2025
    • Ireland
    Hi, I wanted to power on my Dell XPS L702x laptop and the computer turn off the charger.
    I will appreciate if someone can help.
  • andrhouseolly
    Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
    by andrhouseolly
    Hi.
    I kindly ask you to help me solve the problem.
    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
    The board turns on, there is no image.
    Read more. When the power supply is connected, the front panel indicators light up briefly.
    When you press the power button, the button indicator lights up. The board works
    there is no image, there is no matrix initialization, there is no image on HDMI.
    When turned on, the fans do not spin, but when they warm up they start spinning.
    When you turn off the button, the fans spin up to full speed for a short...
    05-11-2024, 03:14 PM
  • BTubbs200
    Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
    by BTubbs200
    Dell Latitude 5420 P137G
    Board: LA-K491P REV A01
    I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
    Board seems to have no shorts, all power rails are fine and show high resistance.
    When charger is plugged in, voltage is present in 3.3V rail but absent in others....
    01-24-2025, 08:15 PM
  • Johndill
    Dell Inspiron 7567 LA-D993P odd charger issue
    by Johndill
    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
    Here are the tested scenarios:
    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
    2. With the laptop off, plug in charger (LED says on) & the front charging...
    11-16-2022, 10:55 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • PowerAmpFreak
    Dell Latitude 7280 does not recognize charger
    by PowerAmpFreak
    I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
    Any common faults that could be fixed?
    I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
    How does the communication between the charger and the PC work?...
    07-28-2025, 07:18 AM
