Acemagic /Nipogi AM06 Pro . Front USB Type C No power
  • 90Ninety
    • Aug 2011
    • 102
    • UK Mains Voltage 240V 50 Hz
    I’m troubleshooting a Nipogi AM06 Pro mini PC (5500U model, also sold as the Acemagic AM06 Pro). The unit generally operates without issues, but the front-facing Type-C port fails to deliver power to any connected peripheral.
    I purchased the system new, so I can’t confirm whether this port was functional at any point. It’s possible the port was miswired during manufacturing. Notably, I did once inadvertently connect the Type-C power adapter to this port, which could have resulted in electrical damage.
    To investigate further, I disassembled the device. My experience includes multiple previous hardware repairs, so I felt comfortable proceeding. I traced the Type-C connector’s voltage pin to a capacitor highlighted in red and to a suspicious component in blue (possibly a diode), both visible in the attached image. The Type-C connector itself appears at the bottom center of the photo. At this stage, I’ve been unable to trace the voltage pin any further downstream from the port.
    Click image for larger version  Name:	ACEIMG_20251030_133401361.jpg Views:	0 Size:	2.48 MB ID:	3755307
    I got out my cheapo microscope to have a closer look at the mystery component, outlined in blue . The text looks like JF N1FL or JF N1FL or something similar . My educated guess is this is at fault . However I have not yet identified it .
    Click image for larger version  Name:	mystery component.jpg Views:	0 Size:	246.4 KB ID:	3755308
    Below are more pictures of the board inside this device
    If anyone has schematics for this board or insights regarding typical failure modes for these Type-C power circuits, I’d appreciate your input.
    Click image for larger version  Name:	IMG_20251030_133027717.jpg Views:	0 Size:	2.52 MB ID:	3755309
    Click image for larger version  Name:	IMG_20251030_133419873.jpg Views:	0 Size:	2.40 MB ID:	3755314
    Click image for larger version  Name:	IMG_20251030_133430693.jpg Views:	0 Size:	2.41 MB ID:	3755311
    Click image for larger version  Name:	IMG_20251030_133356665.jpg Views:	0 Size:	2.82 MB ID:	3755312
  • 90Ninety
    • Aug 2011
    • 102
    Hi
    Just to re-iterate the Device works, and the problem is a a faulty USB port . If someone could simply identify the below component, this would be a great start
    • mon2
      • Dec 2019
      • 14726
      If this part is silk screened as the U16 then this is an IC. Perhaps a PD controller for the local USB-C port. Is this part still onboard? If you are comfortable with the idea, flux and remove it if you are confident it is defective. Perhaps this is a WLCSP packaged PD controller. Once the part is removed, it will require to be reballed to solder this same part back onto the board so you will require a SMD stencil. Alternatively, need a fresh part of the same with factory supplied BGA solder balls. Suggest to pour some IPA alcohol onto the topside of this part to enhance the SMD markings. From a distance, appears to be 'N1BL' but no matches so far...
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
        by sam_sam_sam
        03-31-2024, 02:12 PM
      • nubie
        NUC8i7BEB (BEH) No USB port power schematic/board view
        by nubie
        Got this sweet 8th gen i7 NUC with the Iris graphics for a song. It is a beast, runs 4.5Ghz I am looking for schematic/board view, or just some hints on where to go poking to get some power to my USB ports.
        All USB A ports are without power, including the onboard headers. 2x front, 2x rear.
        I verified that they are enabled in BIOS and I toggled the "sleep state power output" settings too. Also tried the yellow "always on" port with power off or on.
        The C port (Thunderbolt) is fine, and I am using a type C...
        10-11-2023, 06:07 AM
