HP 250 G9 - short circuit 100%
  • Cicciotest
    • Feb 2023
    • 37
    • Italia
    Originally posted by reformatt
    So you're getting no gate drive to PQB11. Check PUB1 which is likely a BQ24780 or BQ24780S. So with charger plugged in, measure the following:
    Pin 28 - VCC
    Pin 5 - ACOK
    Pin 6 - ACDET
    Pin 24 - REGEN
    If VCC is missing, then check PDB1.
    Ok, let me test this in a minutes, i post a reply after testing all you suggested, thanks!
    • Cicciotest
      • Feb 2023
      • 37
      • Italia
      Sems the pin28 has 19v.
      • reformatt
        • Feb 2020
        • 1528
        REGEN is your 6V regulator output. Check resistance of this pin to ground with no power connected. If it's not shorted, the IC is defective and needs to be replaced.
        • Cicciotest
          • Feb 2023
          • 37
          • Italia
          the REGEN (pin 24) whithout power measure 1.57 Kohm ... What does this mean? ...it's not short-circuited.
          Also, maybe I'm wrong. From of the IC diagram, I seem to remember that is the same in this forum:
          - pin 5 was supposed to measure 3V
          - pin 6 was supposed to measure 2.6V
          instead, I got
          - 30mV on pin 5
          - 2.9V on pin 6
          • reformatt
            • Feb 2020
            • 1528
            REGEN is the LDO ref voltage for this IC. Everything else is irrelevant if this is missing. You need to replace the IC.
            • Cicciotest
              • Feb 2023
              • 37
              • Italia
              #26
              Nice, thanks for the explanation, so, i have to change the PUB1 component, this is a start point.
              Thanks again.
