toshiba A200 la3481p
  • mazloum
    • Sep 2012
    • 499
    • Lebanon
    this laptop has a charge problem:
    it did not charge battery:
    1. it works if AC only plugged in
    2. i tried new battery and it will charge for less than one minute then the red led will be off and it displays: plugged in, not charging and the battery will reduce what it is holding charge, even if AC is plugged.
    new battery, new adapter with 6a
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3599
    • slovakia
    Re: toshiba A200 la3481p
    check all pins of charging ic and comparate to ic schematic
    even new things can be broken
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      agree with KTM , somethimes does ebat batterys are defective ( but best option is to chek the voltages present on the charger IC its usually near the ram socket and the dc in (cpu side board view)
      • mazloum
        • Sep 2012
        • 499
        • Lebanon
        i already changed the ic pu4 isl6251 with no success. i put the battery on another laptop it worked good.
        but i noticed that it will remain charging for about 1~2 minutes then shut down when isl6251 becomes hot
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3599
          • slovakia
          changing ic's without know what is bad is not good.
          if it comes hot check for short on pins
          • mazloum
            • Sep 2012
            • 499
            • Lebanon
            it will not come hot fast, it will takes 1~2 minutes to comes hot. also there are no short
            thanks
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              wich is the value you got a Q506 with and without battery ?
              • mazloum
                • Sep 2012
                • 499
                • Lebanon
                there is no q506??
                • highpulse
                  i hate HP
                  • May 2013
                  • 1488
                  • portugal
                  add here you schematic
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    sorry its there allready downlaod , wait
                    was cheking with mine !
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1488
                      • portugal
                      PQ16 source and PQ 18 drain wich voltage you got here ?
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1488
                        • portugal
                        also pin 8 and 10 of the ISL
                        • mazloum
                          • Sep 2012
                          • 499
                          • Lebanon
                          11.84 ~12.?? up and down in this range
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            value with and without battery please
                            also give me values for the ISL pins i mentioned above BTW also pin 4 of the ISL (CELLS)
                            • mazloum
                              • Sep 2012
                              • 499
                              • Lebanon
                              with Ac and no battery: pin 4.8.10=0v and PQ16 source and PQ 18 drain=18.5v
                              with battery but no AC: pin 4.8.10=0v and PQ16 source and PQ 18 drain=11.4v
                              with Ac and battery: (when led is orange first 1~2 minutes)=pin 4= 5v pin8=2.58v and pin10=0.47v and PQ16 source and PQ 18 drain=up and down between 11.74v and 12.0v
                              but after that voltages on pins 4.8.10=0v
                              • mazloum
                                • Sep 2012
                                • 499
                                • Lebanon
                                i am also facing this same problem with lenovo g560
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  isl it get in short , this must be due a bloody cap , or a leeaky FET .. start measuring components on the system charger part , and you will find the culprit . by the way if you have IPA , spray on the board meanwhile is charging , and specially when the ISL start i nshort , spray the IPA on both sides , but each one at the time , and chek were you will notice instant dry on the components , it might help you saving sometimes finding the bad components (dont work always , but worth a try )
                                  • saturday tech noob
                                    • Sep 2014
                                    • 10
                                    I have fixed about 6 Toshiba a200 laptops. All of them needed the nec/token oem128 replaced. As it dies it causes problems like losing power for no reason, losing power when you are running off the battery then plug the charger in and other variations of that.
                                    Here is a link to a youtube video of the best way I have seen to remove the chip https://www.youtube.com/watch?v=cJRLOw0-NsY
                                    I replaced it with 4 of these
                                    http://au.rs-online.com/web/p/tantal...372D3238333226
                                    I have included some before and after pics. Note the 4 caps don't fit so you can try and angle them like I did or you could try doing it dead bug soldering style.
                                    Other people smarter than me worked this all out and I think a lot of the info I got from Bad Caps.
                                    Hope this helps
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      That is with Toshiba A300/L300/L300D not A200, and it's a well known issue. Different laptop, different problem here.
                                      A working TV? How boring!
                                      • alas3376
                                        • Nov 2011
                                        • 382
                                        • BENIN
                                        check well P-channel Mosfet around batterie connector. it's not matter of short-circuit, the Gate and dain loosing
                                          Toshiba Satellite Pro A200-16B Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-16B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-16B boardview and A200-16B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro A200-1MV Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1MV can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1MV boardview and A200-1MV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1KQ Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1KQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1KQ boardview and A200-1KQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1K4 Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1K4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1K4 boardview and A200-1K4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1H4 Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1H4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1H4 boardview and A200-1H4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
