iPad Pro 9.7" A1673
  • garretofriviaaaaa
    • Mar 2024
    • 21
    iPad Pro 9.7" A1673
    Hello, working on an iPad and there is no touch after replacing the battery even with 2 new screens. Need schematics so I can test the diode values on the FPC pins. Thanks
  • asr
    Finding replacement diode iPad Pro 3rd gen A1701
    by asr
    Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
    Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
    07-09-2024, 06:24 PM
  • GeirAndersen
    iPad .pcb file collection
    by GeirAndersen
    I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
    Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
    IPAD COLLECTION 1
    +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
    +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
    +---iPad mini3 820-00008(A1599) 820-00002(A1600)
    +---iPad mini4 820-00180(A1538) 820-00177(A1550)
    +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
    +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
    12-09-2024, 09:28 AM
  • proxneo
    Recapping Sony ICF-SW55 - verifying cap values
    by proxneo
    Dear reader
    I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
    At the moment, I have selected replacements based on the following list of values:
    3 x 470uF 10VDC
    3 x 4.7uF 35VDC
    4 x 47uF 50VDC
    8 x 22uF 6.3 VDC
    1 x 220uF 6.3VDC
    5 x 100uF 6.3VDC
    Which...
    06-21-2023, 12:38 AM
  • trepachka
    iPad Air A1475 Boot loops after replacing battery
    by trepachka
    This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
    The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
    I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
    11-08-2024, 03:17 PM
  • ipatch
    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
    by ipatch
    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
    08-24-2024, 02:36 PM
