MacBook Air M2 820-02536 trackpad not working
  • daltonjr.
    • Jul 2016
    • 51
    • Austria
    I have this MacBook that I can not restore, because trackpad is not working. I have tried other topcases, trackpads, cables.... no su​ccess. I have replaced UT360 twice and UT320, no lu​ck.
    Main power lines are present, but at:
    SPI_IPD_MOSI_CONN = 0V
    SPI_IPD_MCU_CS_CONN_L = 3.28V​
    SPI_IPD_MISO_CONN = 0V
    IPD_SYS_AWAKE_CONN = 0V
    Maybe someone has better u​nderstanding of these circu​its and can help. Thank you​.
  • mon2
    • 14718
    SPI_IPD_MOSI_CONN - master out; slave in - no traffic from the bus master (logic board)
    SPI_IPD_MCU_CS_CONN_L - active LOW signal (denoted by the _L suffix) - since this is a logic '1' - the trackpad is not being selected
    • daltonjr.
      • Jul 2016
      • 51
      • Austria
      Meaning? 🤔
      SPI_IPD_MOSI at UT360 is 0V, that comes from CPU. ​
      • mon2
        • 14718
        Confirm the power rails on this level shifter @ UT360.
        Any activity on the other signals on UT360 from the bus master?
        Does this unit power up otherwise?
        • daltonjr.
          • Jul 2016
          • 51
          • Austria
          Yes, it does power up. No water damage.Keyboard works. Here are all values at UT360​.
          • SPI_IPD_MCU_CS_L = 1,25V
          • SPI_IPD_CLK = 0V
          • SPI_IPD_MOSI = 0V
          • SPI_IPD_MISO_R = 0V
          • PP1V2S2 = 1,25V
          • SPI_IPD_MISO_CONN = 0V
          • SPI_IPD_MOSI_CONN_R = 0V
          • SPI_IPD_CLK_CONN_R = 0V
          • SPI_IPD_MCU_CS_CONN_L = 3.28V
          • PP3V3_S2SW_IPD = 3,28V
          • daltonjr.
            • Jul 2016
            • 51
            • Austria
            Bump🥶
            • mitchw
              MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
              by mitchw
              Hello
              I got this MacBook Pro M4 Pro to have a look at.
              It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
              Since it was liquid damaged, warranty does not apply anymore.
              Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
              The main issue was that the screen remained black.
              Anyways I cleaned the liquid damaged area, put the machine back...
              09-06-2025, 07:19 AM
            • No Lan
              [Macbook pro A1708] [Boot loop] [Trackpad ?]
              by No Lan
              Hey everyone,
              Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
              Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
              Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
              05-24-2025, 03:09 PM
            • Woodsworth
              MacBook Pro A2289 no signs of life except clicking trackpad and charging
              by Woodsworth
              I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
              "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
              It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
              03-15-2024, 04:06 AM
            • Vliegenier04
              Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
              by Vliegenier04
              Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
              I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
              Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
              06-16-2025, 12:03 PM
            • biosdi
              MacBook Pro A1989 trackpad and keyboard not working
              by biosdi
              Hi guys.
              I Just replaced battery on my MacBook Pro A1989. Unfortunately doing that, I’ve broken the trackpad flex cable (821-01701-a), and I’ve already ordered a spare one. At the same moment I’ve noticed that also the keyboard it’s not working anymore and I’ve found an SMD chip unsoldered and moving freely inside the backplate. I can read L20L on the chip. Is something could explain the keyboard not working or the keyboard doesn’t work due the unconnected trackpad?
              thanks...
              04-17-2025, 09:42 AM
