ASUS TUF Dash Motherboard FX516 REV 6.0 Model Device Not Charging
  • lazenes
    • Jun 2016
    • 25
    • Türkiye
    The device is not charging with the 19V 180W DC charger. If the battery is full, the laptop powers on normally. I can charge it via USB Type-C, but it’s very slow. I checked the schematics but couldn’t find a solution. I even replaced the BQ24800 battery charging IC, but the issue remains the same. I suspect a MOSFET or a fuse that I might be overlooking is preventing it from charging with the adapter. Has anyone experienced a similar fault before or has any advice?
  • mon2
    • Dec 2019
    • 14544
    Attach the power adapter. Measure the voltage to ground of:
    ACDET
    REGN
    ACDRV
    • lazenes
      • Jun 2016
      • 25
      • Türkiye
      ACDET
      REGN
      ACDRV
      Thanks for your reply. Could you please let me know which voltages or signals I should measure and at which test points or pins? That would help me narrow down the problem. (For example, ACDET = 14v)
      • mon2
        • Dec 2019
        • 14544
        See attached. Proceed only if your meter leads are fine tipped. Otherwise, the short circuit of the pins can be lethal to the board.
        Black meter lead to ground. Red (fine tipped) lead to pin to test. Meter in 30V dc scale or higher.
        If all is well, ACDRV should be ~25v. REGN should be ~6v. ACDET must be 2v4 or higher else the DCin mosfets will remain disabled.
        • lazenes
          • Jun 2016
          • 25
          • Türkiye
          Click image for larger version  Name:	top_view.png Views:	20 Size:	77.6 KB ID:	3728113
          I checked the voltages as you suggested. ACDRV is around 25V, REGN is about 6V, and ACDET is above 2.4V, so the readings look fine. However, the battery still does not charge with the DC adapter. Do you have any idea what else I should check?
          • mon2
            • Dec 2019
            • 14544
            Remove all power. Meter in resistance mode. Measure the resistance directly on pins 19 & 20 on the charger ic. One meter probe on pin # 19. Other meter probe on pin # 20. What is the resistance in ohms?
            • lazenes
              • Jun 2016
              • 25
              • Türkiye
              I removed all power and measured directly on pins 19 and 20 of the charger IC with my UNI-T UT33D+ multimeter set to the 200Ω range. The reading was about 20.8 ohms.
              • mon2
                • Dec 2019
                • 14544
                This leg of the circuit is OK (comparing against the schematics of v4.0) = ~20 ohms.
                Remove the pre-charged battery. Attach only the power adapter. Does the logic board power up normally? If not, measure the voltage to ground of the DCin mosfets.
                PQ8901 (1st mosfet)
                source (1-2-3)
                gate (4) ; should be ~25v
                drain (5-6-7-8)
                PQ8902 (2nd mosfet)
                source (1-2-3)
                drain (5-6-7-8)
                • mon2
                  • Dec 2019
                  • 14544
                  Measure the voltage to ground of the following with the power adapter and battery:
                  MB_MAX_POWER ; this voltage is critical and defines what the logic board is detecting as the power rating of your external power adapter
                  If this voltage is not correct, the battery will not charge.
                  • lazenes
                    • Jun 2016
                    • 25
                    • Türkiye
                    PQ8901 (1st mosfet)
                    source (1-2-3)
                    drain (5-6-7-8)
                    PQ8902 (2nd mosfet)
                    source (1-2-3)
                    drain (5-6-7-8)
                    Click image for larger version  Name:	dcin_mosfets.png Views:	0 Size:	71.0 KB ID:	3729129
                    I have taken the voltage measurements you requested on PQ8901 and PQ8902. I marked all the readings directly on the schematic/image and attached it here for your review
Name:	WhatsApp Image 2025-09-20 at 16.15.04.jpg
                    • lazenes
                      • Jun 2016
                      • 25
                      • Türkiye
                      [QUOTE=mon2;n3729133]Measure the voltage to ground of the following with the power adapter and battery:
                      I couldn't read the value at MB_MAX_POWER. In my schematic, under the IO integrated circuit, this point.
Name:	WhatsApp Image 2025-09-20 at 16.37.07.jpg
ID:	3729157 Click image for larger version
Name:	Ekran görüntüsü 2025-09-20 163505.jpg
                      • mon2
                        • Dec 2019
                        • 14544
                        Confirm the presence of a RTC battery. Measure the voltage to ground of this battery which should be ~3v.
                        (from another board schematic but should be similar to yours)
                        • lazenes
                          • Jun 2016
                          • 25
                          • Türkiye
Name:	WhatsApp Image 2025-09-20 at 16.59.00.jpg
                          In my board, the battery is integrated (not removable) and the related +3V circuit components shown in the schematic are missing. The battery circuit area is also empty, so it seems incomplete compared to the diagram.
                          • mon2
                            • Dec 2019
                            • 14544
                            Ok. Confirm if you have ~3v on the other side of resistor R8935. This voltage is required to have a non-zero voltage @ MB_MAX_POWER.
                            • lazenes
                              • Jun 2016
                              • 25
                              • Türkiye
                              I checked resistor R8935, but there is no 3V on either side of it.
                              • mon2
                                • Dec 2019
                                • 14544
                                Does the board power up ok without the battery but using only the power adapter? The adapter power rating is not being sensed properly due to the above circuit. This is required to inform the logic board that the adapter is capable of powering the board AND charge the battery pack.
                                • lazenes
                                  • Jun 2016
                                  • 25
                                  • Türkiye
                                  Without the battery, the board does not power on with only the adapter. With the battery installed, it powers on but still does not charge. In this case, what can be done to repair/restore the MB_MAX_POWER circuit so that the adapter power rating can be detected correctly?
                                  • mon2
                                    • Dec 2019
                                    • 14544
                                    Can you share the boardview diagram for your board? It is not in my database. Or link in the schematic sub-forum. Is the boardview diagram matching your board exactly?
                                    • lazenes
                                      • Jun 2016
                                      • 25
                                      • Türkiye
                                      The schematic I have is for rev 4.0, while my actual board is rev 6.0. The diagram matches about 85% of the board, but there are some differences.
                                      • mon2
                                        • Dec 2019
                                        • 14544
                                        Locate and measure the voltage to ground on each leg of SL3006.
                                        • cope
                                          Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                                          by cope
                                          I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                                          Some history:
                                          Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                                          As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                                          Now, with a new battery the system will start up and run off...
                                          05-13-2024, 09:40 AM
                                        • GoCoSoftware
                                          Need schematic & boardview for Asus Tuf Dash F15 - Motherboard FX516PC r6.0
                                          by GoCoSoftware
                                          Hello I think I broke my motherboard when trying to upgrade the Ram!
                                          I made some shortcut when pluggining the battery connector because the thiny metal goes over nearest components and made sparks.
                                          The laptop won't poweron anymore so I need to check the motherboard to reveal if there is any shortcut.
                                          Could be great if some of You can share boardview for my motherboard FX516PC r6.0
                                          Thanks.
                                          Giuliano.
                                          10-11-2024, 02:49 AM
                                        • glovecaps
                                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                          by glovecaps
                                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                          11-25-2024, 04:23 PM
                                          ASUS TUF Dash FX517ZM-HN093 Notebook F15 Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Dash FX517ZM-HN093 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX517ZM-HN093 boardview and FX517ZM-HN093 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 06:38 AM
                                          ASUS TUF Dash FX516PM-71B36CS2 Notebook F15 Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Dash FX516PM-71B36CS2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-71B36CS2 boardview and FX516PM-71B36CS2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:20 AM
