ASUS TUF Dash Motherboard FX516 REV 6.0 Model Device Not Charging
  • lazenes
    • Jun 2016
    • 41
    • Türkiye
    #61
    Originally posted by mon2
    Remove all power. Measure the resistance across PR8913. Is the resistance close to the schematic value? If yes, measure the resistance to ground of the point with 0R ohms. Either the PR8913 resistance is too high or there is a short on this line. From the board view diagram, there should be a voltage here.
    I've removed all power and measured the resistance across PR8913. I'm getting around 60k ohms, but the schematic shows it should be 120k ohms.
    It seems the resistance is not close to the schematic value, being roughly half. Does this suggest the resistor itself is faulty, or could it still indicate a short on the line?
    • mon2
      • 14685
      This measurement may be off due to the fact that the resistor is in-circuit as compared to being removed and on your work bench. On your work bench, the measurement will be more accurate.
      However, at 60k ohms, you should still have a voltage on pin #21 (ILIM) unless this pin is being shorted to ground.
      Remove all power. Measure the resistance to ground of pin #21 (ILIM). We are now checking if the resistor @ PR8914 is shorted or not. What is the resistance in ohms?
      Based on the shared information, if PR8914 is not shorted, then there should be a voltage on pin #21 (ILIM) to define the peak charge current for the battery.
      • lazenes
        • Jun 2016
        • 41
        • Türkiye
        #63
        I measured the resistance between PR8914 and ground, and it is about 87 ohms
        • mon2
          • 14685
          Ok. That explains it. Flux and remove PR8914 off the board. Do not lose the part. Then allow it to cool and measure it again. Is this part still ~87R ohms?
          Assuming yes, hunt for any part you may have that is close to the schematic value of 68K ohms. This value is not critical. Even leaving the resistor off should be ok but then we are applying ~3v onto this ILIM setting and requesting the charger IC to use a high current to charge the battery. I think it will be safe to do so for initial testing but long term solution is stuff a valid resistor @ PR8914.
          • lazenes
            • Jun 2016
            • 41
            • Türkiye
            #65
            I removed PR8914 and measured it out of circuit. The value is 67.9kΩ, so it seems normal. Should I try powering the board with the adapter while the resistor is removed?
            • mon2
              • 14685
              Measure the resistance to ground of the ILIM pin (without the PR8914 resistor). Suspecting that you will still have a low resistance to ground on this pin.
              • lazenes
                • Jun 2016
                • 41
                • Türkiye
                #67
                ~87R ohms
                When I measure PR8914 out of circuit, it reads about 68kΩ. But when I solder it back on the board, the resistance drops to around 87Ω. What does this mean?
                • mon2
                  • 14685
                  Leave PR8914 off the board. Then measure the resistance to ground again at pin #21 (ILIM). What is the resistance without PR8914 soldered on the board?
                  • lazenes
                    • Jun 2016
                    • 41
                    • Türkiye
                    #69
                    With PR8914 removed from the board, I measured the resistance to ground at pin #21 (ILIM) and it reads about 101Ω.
                    • mon2
                      • 14685
                      Check if you have a capacitor @ PC8911 on your board. If yes, flux and remove it. This capacitor may be shorted. Then measure the resistance again at this pin to ground.
                      • lazenes
                        • Jun 2016
                        • 41
                        • Türkiye
                        #71
                        "I removed PC8911, but nothing changed. The resistance to ground at pin #21 (ILIM) is still the same."
                        • mon2
                          • 14685
                          Any liquid damage to PU8900? Has this part been replaced in the past? This resistance is too low on this pin. If no liquid damage then this charger IC may be defective.
                          You can also confirm the same by testing diode mode. Remove all power. Meter in diode mode. Red meter lead to ground. Black meter lead onto this same ILIM pin.
                          What is the measurement?
                          • lazenes
                            • Jun 2016
                            • 41
                            • Türkiye
                            #73
                            I am measuring 108 ohms in diode mode.
                            The integrated circuit hasn't changed. I took it out and put it back in.
                            I guess I should order a new PU8900 integrated circuit and try it out.
                            • mon2
                              • 14685
                              In diode mode, the units of measurement will be in volts. Double check if you are in diode mode. To confirm, touch your meter probes together and you should hear a tone beep.
                              • lazenes
                                • Jun 2016
                                • 41
                                • Türkiye
                                #75
                                I guess I should order a new PU8900 integrated circuit and try it out..
                                0.094v​
                                • mon2
                                  • 14685
                                  Yes, I would agree. Order a spare as they are not too expensive. The diode measurement is showing this line as being shorted.
                                  • lazenes
                                    • Jun 2016
                                    • 41
                                    • Türkiye
                                    #77
                                    I already ordered a new PU8900 and replaced it, but unfortunately the behavior is still the same. Looks like this issue is deeper. Honestly, ASUS is nothing but disappointment — the official service only suggested a full board replacement, but at that price here in my country I could easily buy a different model laptop instead.
                                    • mon2
                                      • 14685
                                      Post all pin voltages to ground on pu8900 with adapter and battery connected. Include the PIN numbers and their labels for easier reference.
                                      • cope
                                        Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                                        by cope
                                        I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                                        Some history:
                                        Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                                        As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                                        Now, with a new battery the system will start up and run off...
                                        05-13-2024, 09:40 AM
                                      • GoCoSoftware
                                        Need schematic & boardview for Asus Tuf Dash F15 - Motherboard FX516PC r6.0
                                        by GoCoSoftware
                                        Hello I think I broke my motherboard when trying to upgrade the Ram!
                                        I made some shortcut when pluggining the battery connector because the thiny metal goes over nearest components and made sparks.
                                        The laptop won't poweron anymore so I need to check the motherboard to reveal if there is any shortcut.
                                        Could be great if some of You can share boardview for my motherboard FX516PC r6.0
                                        Thanks.
                                        Giuliano.
                                        10-11-2024, 02:49 AM
                                      • glovecaps
                                        by glovecaps
                                        11-25-2024, 04:23 PM
                                        ASUS TUF Dash FX517ZM-HN093 Notebook F15 Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Dash FX517ZM-HN093 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX517ZM-HN093 boardview and FX517ZM-HN093 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-07-2024, 06:38 AM
                                        ASUS TUF Dash FX516PM-71B36CS2 Notebook F15 Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Dash FX516PM-71B36CS2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-71B36CS2 boardview and FX516PM-71B36CS2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 05:20 AM
