A2992 no battery charging
  • defdjamel
    • Jul 2025
    • 20
    • france
    i am completely stuck on this board , who not charging battery(battery tested ok in other logic board).
    SMBUS_BATT_SDA, SCL : 1.8V no oscillation. diode 0.5
    SYS_DETECT_L = 0V
    CHGR_RST_IN 0V
    DISP = 0V
    ppvbat_AON 12V
    pulup resisiatnce SMBUS_BATT_SCL./SDA : 3.3Kohm
    I2C_SMC_PWR_SCL /SDA = 1.2V no oscillation ,
    UD102 changed
    battery connector are ok
    i am stuck .
    if you have an idea...​
  • mon2
    • Dec 2019
    • 14728
    Has the LCD been replaced or is the original? Do you have True Tone feature?
    • defdjamel
      • Jul 2025
      • 20
      • france
      thanks for your reply , lcd has not been replaced , but logic board is not connected to any screen during the test. charging battery not need screen.
      • mon2
        • Dec 2019
        • 14728
        Earlier this year - the Mx series had a LCD fault where the replacement screens would cause the charging to fail. Attach the LCD to test if the issue is resolved while using the display.
        • defdjamel
          • Jul 2025
          • 20
          • france
          thanks i will check that today.
          • defdjamel
            • Jul 2025
            • 20
            • france
            And regarding my voltage measurements, is there anything bad?
            CHGR_RST_IN 0V is normal ?
            • mon2
              • Dec 2019
              • 14728
              Test the voltages on U7440 (Silego component).
              Is there PP1V8_AON on U7440, pin #1 ?
              Does PMU_ONOFF_L pulse when the ON/OFF button pads are shorted? Then confirm the same for PMU_ONOFF_R_L.
              The output of CHGR_RST_IN (pin 10 on U7440) should also pulse with this activity. Follow the pulsing to the output of PMU_SHDN signal.
              To me, this is the ON/OFF logic board signal path.
              • defdjamel
                • Jul 2025
                • 20
                • france
                hi , i already investigate U7440 .
                i have changed the component.
                here measurement:
                PP1V8_AON = 1.8V
                PMU_ONOFF_L : 1.8 v and pulse at power ON/OFF
                PMU_ONOFF_R_L​ : 1.8v and pulse during off
                CHGR_RST_IN = 0V and no pulse.
                PMU_SHDN​ = 0V and no pulse.
                i will resolder u7440
                • defdjamel
                  • Jul 2025
                  • 20
                  • france
                  i make a mistake on my measurement on PPVBAT_AON : 1V with small oscilation to 0.5V.
                  PPVBAT_AON_CHGR_R = 12V
                  CHGR_BGATE = 12V
                  CHGR_BGATE need to be 0V for mosfet Q5265
                  • defdjamel
                    • Jul 2025
                    • 20
                    • france
                    I2C_SMC_PWR_1V8_SCL / SDA were stuck at 1.8 V with no oscillation.
                    I checked I2C_SMC_PWR_SCL / SDA before UD1021.2 V with small oscillation.
                    I connected the oscilloscope and saw signal activity on I2C_SMC_PWR_SCL, but nothing on I2C_SMC_PWR_1V8_SCL / SDA.
                    After replacing UD102 driver, now it works correctly and the battery is charging.
                    another tricky board brought back to life! 💪😎
                    • mon2
                      • Dec 2019
                      • 14728
                      You had replaced UD102 mentioned in the first post. It was replaced again or just needed a reflow?
                      • defdjamel
                        • Jul 2025
                        • 20
                        • france
                        right , i have replaced ud102 , without checking the oscilation on SCL, only SDA , chip was not working on SCL or bad soldering.
                        i have check second time and see the communication problem.
                        thanks for you reply. this board got a big liquid damage on keyboard , trackpad connector ,battery was shorted and dead.
                        now everything is working.
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • Julian Bailey
                          HP ProBook 445 G8 Battery not charging
                          by Julian Bailey
                          Hi all
                          We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                          The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                          I have gone around the board with a MM and cant find anything
                          Windows shows the battery fine,...
                          10-11-2024, 10:34 AM
                        • piernov
                          Laptop battery charging circuit
                          by piernov
                          1. Some theory
                          1.1. Introduction
                          Almost every laptop has a charging circuit of some sort, that does a few things:
                          • Manages switching between AC adapter and battery power
                          • Manages battery charging and generates power rail to charge battery
                          There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                          • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                          • Narrow VDC (NVDC)
                          Texas instrument has a nice overview of these technologies with some more details at https:...
                          11-15-2020, 01:31 PM
                        • kodox
                          ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                          by kodox
                          since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                          the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                          what i've done:
                          - flashing...
                          12-29-2024, 02:49 AM
                        • Shinju
                          Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                          by Shinju
                          Hey All!
                          Long time forum member here with a problematic laptop issue!
                          I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                          The laptop would not power on with the new battery installed without the power supply being plugged in.
                          When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                          TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                          10-20-2021, 04:58 PM
