lenovo yoga 7-15itl5 after battery breaks
  • Honziq
    • May 2014
    • 65
    • Kazaksa
    my Lenovo with board GYG41/GYG51/NM-D131 wont turn on.
    It has dead battery - 0V, one cell is completly bad.
    But it wont turn on even without battery, reset switch didnt help.
    It got only 3,3V, 1,8V and 3,7V?? maybe that should be 5V rail idk.
    And UU1 (SN1905004YBGR) is getting hot after charger is connected.
    Can it be dead UU1 or it is some short behind it?
    What should I check?
    Thank you for any advice.
  • mon2
    • 14691
    If this part is getting hot then perhaps you do have a short on one of the downstream rails. Remove all power. Meter in resistance mode. Measure the resistance to ground on each of the power rails (input / output as well). Hunting for any rail with a low resistance.
    That is,
    VBUS_TBTA
    VBUS_TBTB
    VCC3_LDO_PD
    +5VALW
    • Honziq
      • May 2014
      • 65
      • Kazaksa
      That is,
      VBUS_TBTA
      VBUS_TBTB
      VCC3_LDO_PD
      +5VALW
      Thank You,
      VBUS_TBTA 42,4 ohm
      VBUS_TBTB 25 kOhm
      VCC3_LDO_PD 35,3 ohm
      +5VALW 39,6 ohm
      and
      3VALW_TBTA 1,7ohm
      3VALW_TBTB 1,7ohm
      There are no shorts, but 1,7 ohm is suspicious enough?
      Should I try to inject voltage in it?
      Thank you very much.
      • mon2
        • 14691
        +5VALW 39,6 ohm
        are also suspects. Often linked to the usb ports since they consume the 5v rail for vbus. Do investigate the usb load switches that should be nearby the usb ports. On a bad event, they trigger and cause this rail to tank.
        Yes, ok to voltage inject. Keep voltage low and monitor for who heats up.
        • Honziq
          • May 2014
          • 65
          • Kazaksa
          +5VALW 39,6 ohm
          After 3VALW_TBTB was injected 1V, one of Intel retimers (UU8) heats up, 3VALW_TBTA heats up first retimer for USBC (UU3).
          Other rails doing nothing, maybe if I turn voltage up little bit?
          • Honziq
            • May 2014
            • 65
            • Kazaksa
            I can’t belive both retimers are bad.
            That 5V rail if I inject 1V its only 0,025A, so it can’t heat anything.
            Interesting thing is when laptop is connected to charger it draws 1,3w from it and UU1 and UU3 was getting hot (UU3 only little bit), second USB C draws 0,3W and only UU1 was getting hot.
            I’m also wondering, if that laptop isn’t designer to work without battery?
            • Honziq
              • May 2014
              • 65
              • Kazaksa
              • Honziq
                • May 2014
                • 65
                • Kazaksa
                It looks like the main short is direcrly in UU1 and maybe also in both retimers. But they all are BGA so i can’t prove it by removing that parts. Also it will be problem change retimer I can’t reprogram it.
                • Honziq
                  • May 2014
                  • 65
                  • Kazaksa
                  After UU1 was removed:
                  VBUS_TBTA short gone
                  VBUS_TBTB 25 kOhm
                  VCC3_LDO_PD short gone
                  +5VALW short gone
                  and
                  3VALW_TBTA short gone
                  3VALW_TBTB 1,7ohm
                  maybe I should try to remove UU8 to get rid of that last short and order new UU1 and UU8.
                  Hopefully it will solve that problem.
                  I have to learn how to solder it back in place.
                  • PitMakot
                    • Mar 2018
                    • 12
                    • Poland
                    Honziq
                    Did you replace UU1 and UU8?
                    Were you able to fix it?
                    • ferah831208
                      by ferah831208
                      03-18-2025, 01:18 AM
                    • mrkmpn
                      Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                      by mrkmpn
                      Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                      This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                      03-13-2024, 01:54 PM
                    • emeskay
                      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                      by emeskay
                      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                      08-06-2024, 07:13 AM
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • NConstantinou
                      LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
                      by NConstantinou
                      Dear all,
                      i have the above laptop which had a problem with battery. i replaced it with a compatible one..
                      the laptop DOES NOT POWER ON..
                      with it old battery it does power on.
                      i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
                      when i shutdown the laptop does not power on.
                      does anyone have any solution!
                      when is not power on the usb c voltage tester shows 5v 1.3A
                      when i disconnect battery and power on and then connect battery the tester...
                      12-10-2024, 04:52 AM
