macbook pro a1707 dead
  • jesi
    • Jul 2013
    • 74
    hi all techs
    require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
    adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
    update:
    when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from 4.96v to 20.25v after 2 to 3 secs they drop to 19.77v
    attached a photo of the mb with all the voltages on the top side which i managed to note down are wdotted down on the attached photo of mb,
    i only get these voltages when the battery is disconnected and the adapter is connected, when battery flex is connected the macbook does not respond to anything no voltages except the usb c voltages
    i was thinking of flashing the bios to start with but not able to find the right one for it , so have not touched until i get a repnse from yourside
    these voltages i only get when the battery flex is disconnected from the mb
    thankyou in advance
  • mon2
    • Dec 2019
    • 14470
    Check if PPBUS_G3H and 3V42 rails are stable.
    • dariusgc
      • May 2020
      • 38
      • Lithuania
      i've got the same mac. Want t know, maybe someone knows what normal resistance are on L7960 and L8000 phase inductors?
      Thanks in advance. 🙏
      • mon2
        • Dec 2019
        • 14470
        These are low voltage rails so the resistance is expected to be low as well. Remove all power. Measure their resistance to ground and post the results.
        • dariusgc
          • May 2020
          • 38
          • Lithuania
          Those two inductors show ~50 Ohms. Is it normal?
          • mon2
            • Dec 2019
            • 14470
            Yes. To me, these are ok.
            What is wrong with the unit? What is the voltage to ground of PPBUS_G3H?
            Also measure, ALL_SYS_PWRGD voltage to ground.
            • jesi
              MacBook Pro 820-00281-A A1707 macbook
              by jesi
              hi all techs
              update:
              when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
              08-23-2025, 02:35 PM
            • Royco
              Macbook A1707 tottaly dead
              by Royco
              guys i have problem with macbook pro A1707 ic UB700(TBT regulator),it doesnt have output voltage and the board just have 0,230 amper;19 volt, but the trackpad can click, i dont have idea this is processor or Thunderbolt
              07-21-2024, 06:51 AM
            • AdrenalinTL
              Macbook Pro A1707 - Dead - Battery 'popped'
              by AdrenalinTL
              Hi Peeps.
              Just a quick question please as I am by no means an Apple fundi at all.
              Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
              Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
              Don't want to go buy a battery for no reason.
              Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
              07-18-2024, 09:52 AM
            • dellxps15
              macbook a1707 15 inch trackpad dead. blown fuse identification
              by dellxps15
              hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
              another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
              04-30-2024, 10:48 AM
            • leonemax81
              Macbook a1707 820-00281 Battery no Power
              by leonemax81
              Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
              08-23-2024, 09:24 AM
