macbook pro a1707 dead
  • jesi
    • Jul 2013
    • 78
    hi all techs
    require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
    adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
    update:
    when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from 4.96v to 20.25v after 2 to 3 secs they drop to 19.77v
    attached a photo of the mb with all the voltages on the top side which i managed to note down are wdotted down on the attached photo of mb,
    i only get these voltages when the battery is disconnected and the adapter is connected, when battery flex is connected the macbook does not respond to anything no voltages except the usb c voltages
    i was thinking of flashing the bios to start with but not able to find the right one for it , so have not touched until i get a repnse from yourside
    these voltages i only get when the battery flex is disconnected from the mb
    thankyou in advance
  • mon2
    • Dec 2019
    • 14685
    Check if PPBUS_G3H and 3V42 rails are stable.
    • dariusgc
      • May 2020
      • 45
      • Lithuania
      i've got the same mac. Want t know, maybe someone knows what normal resistance are on L7960 and L8000 phase inductors?
      Thanks in advance. 🙏
      • mon2
        • Dec 2019
        • 14685
        These are low voltage rails so the resistance is expected to be low as well. Remove all power. Measure their resistance to ground and post the results.
        • dariusgc
          • May 2020
          • 45
          • Lithuania
          Those two inductors show ~50 Ohms. Is it normal?
          • mon2
            • Dec 2019
            • 14685
            Yes. To me, these are ok.
            What is wrong with the unit? What is the voltage to ground of PPBUS_G3H?
            Also measure, ALL_SYS_PWRGD voltage to ground.
            • dariusgc
              • May 2020
              • 45
              • Lithuania
              It powers on, fan spins non stops, cpu not hot.
              PPBUS_G3H = 12V.
              ALL_SYS_PWRGD = 3.3V.
              Maybe bios is coruppted?
              • mon2
                • Dec 2019
                • 14685
                Fan spin often is linked to missing the detection of the sensors in the trackpad. This results in high fan spin and the CPU will be throttled.
                Disconnect the trackpad cabling and test if the results are the same. The logic boards should feature shorting pads to mimic the power on/OFF button using tweezers.
                • dariusgc
                  • May 2020
                  • 45
                  • Lithuania
                  Without trackpad the fan spinning super fast, like turbine. Shorting pads of DEV-POWER BUTTON do nothing.
                  • mon2
                    • Dec 2019
                    • 14685
                    Try the bios in post # 2 here:
                    https://www.badcaps.net/forum/troubl...2159-820-00281
                    Backup the original 2 times and verify the contents before erasing and using the new image.
                    • dariusgc
                      • May 2020
                      • 45
                      • Lithuania
                      Thanks , i'll try. Let you know.
                      • dariusgc
                        • May 2020
                        • 45
                        • Lithuania
                        Hm, the same problem, fan spining, cpu is cold...😏
                        • dariusgc
                          • May 2020
                          • 45
                          • Lithuania
                          I've found very low resistance to ground, it is ~0.7-0.8 Ohm on L7330 inductor. This is PPVCCSA_S0_CPU rail. Is that resistance is normal or cpu is dead?
                          • mon2
                            • Dec 2019
                            • 14685
                            It may be, review this thread:
                            https://boards.rossmanngroup.com/thr...a_s0_cpu.6401/
                            • mon2
                              • Dec 2019
                              • 14685
                              Wait, you have ppbus_g3h so cpu is not dead from the high side mosfet. The cpu will heat up normally without a heatsink. Test the vcore voltage to ground.
                              • dariusgc
                                • May 2020
                                • 45
                                • Lithuania
                                There is no voltage on vcore rail . cpu is cold as ice. I meassured PPVCCSA_S0_CPU more accuratley there is 0.2-0.3 ohm reading...
                                • jesi
                                  MacBook Pro 820-00281-A A1707 macbook
                                  by jesi
                                  hi all techs
                                  update:
                                  when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                                  08-23-2025, 02:35 PM
                                • Royco
                                  Macbook A1707 tottaly dead
                                  by Royco
                                  guys i have problem with macbook pro A1707 ic UB700(TBT regulator),it doesnt have output voltage and the board just have 0,230 amper;19 volt, but the trackpad can click, i dont have idea this is processor or Thunderbolt
                                  07-21-2024, 06:51 AM
                                • AdrenalinTL
                                  Macbook Pro A1707 - Dead - Battery 'popped'
                                  by AdrenalinTL
                                  Hi Peeps.
                                  Just a quick question please as I am by no means an Apple fundi at all.
                                  Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
                                  Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
                                  Don't want to go buy a battery for no reason.
                                  Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
                                  07-18-2024, 09:52 AM
                                • dellxps15
                                  macbook a1707 15 inch trackpad dead. blown fuse identification
                                  by dellxps15
                                  hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                                  another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                                  04-30-2024, 10:48 AM
                                • CG_Dionysos
                                  MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                                  by CG_Dionysos
                                  I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                                  • Model: A1707
                                  • 15-inch, Mid 2017
                                  • 3.1 GHz Core i7
                                  • 16 GB RAM
                                  • Radeon Pro 560
                                  • 1 TB SSD
                                  • Board number: 820-00928-A
                                  I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                                  Thanks in advance!
                                  Greetings from Germany...
                                  09-16-2025, 06:43 AM
