A1708 820-00875 won't power on; 20V 500mA initially, then 0A.
  • ipmungam
    • Nov 2021
    • 16
    Our 2016 13" mbp has had some issues since liquid got into one of the USB-C ports a few years ago, but it was working well with the latest (aftermarket) battery for several weeks -- until now.
    With the board out and no battery, it negotiates 20V properly and starts to take 300-600mA (let's call this phase 1). With the screen attached it will even show the red low battery icon. Then after 5-10s the current drops to near zero and nothing more happens (phase 2). Power button has no effect.
    I have checked all the coils I can see while unpowered and none seem shorted to ground. PPBUS_G3H is 13V during both phase 1 and 2; the other power rails seem to power on during phase 1 (I only have a few seconds to check, so can't be sure, but the display briefly works so must be something right). However most everything other than PPBUS_G3H goes to exactly 0V in phase 2. It's as though they're being shut down.
    Any thoughts most welcome.
  • mon2
    • 14814
    Flux and remove F7000. Power up again. What is the voltage to ground on the removed fuse pcb pad # 1 ? Is it stable or still power cycling?
    • ipmungam
      • Nov 2021
      • 16
      Thanks very much for the speedy reply -- I will try this and report back.
      • ipmungam
        • Nov 2021
        • 16
        Hello again. Took some work but I got F7000 off -- now the board negotiates 20V but never takes more than 20mA, which I suppose makes sense.
        The voltage at the F7000 pin is a steady 13V. This is consistent with when the fuse was in -- it wasn't power cycling so much as it seemed to start the pre-boot process (phase 1), but then got interrupted at some step and shut down the rest of the power rails.
        • ipmungam
          • Nov 2021
          • 16
          I've tested resistance to ground for all the power rails I can see listed in the schematic -- no shorts as far as I can tell.
          This suggests I'm missing an enable signal somewhere -- any suggestions on where to start looking would be welcome.
          • mon2
            • 14814
            Do you see the same low battery graphic with and without the battery attached? Can you test with another known good battery? Amazon?
            • ipmungam
              • Nov 2021
              • 16
              Thanks. With F7000 removed I have reinstalled the board with the "new" battery (recently bought on Amazon and worked for 1-2 weeks) and "old" battery (bought aftermarket a few years ago, swollen cell). [I don't have the "original" battery anymore.]
              0. No battery: 20V, draws 0-40mA, no longer seeing the low battery screen (to see an image does F7000 need to be in place?).
              1. New battery: 5V, power cycles every time it tries to reach 20V.
              2. Old battery: 20V, draws 0-40mA, no screen.
              • mon2
                • 14814
                Yes. Add fuse. Test again and confirm the graphics.
                • ipmungam
                  • Nov 2021
                  • 16
                  Just got back to this, F7000 is now back in. Yes, with the old battery attached the behaviour is exactly the same as first reported, but now with an extra ~300mA draw -- the low battery graphic comes on both with and without the battery, but shortly after that the current draw drops to zero (or to 300mA if the battery is attached).
                  Seems as though the new battery failed and in doing so took some enable signal(s) somewhere in the power up sequence with it.
                  • mon2
                    • 14814
                    Attach the battery. Measure the voltage to ground of each pin on the battery connector. Post each measurement.
                    • ipmungam
                      • Nov 2021
                      • 16
                      Thanks again. I left the old battery in and on charge last night, and this morning the machine made it to the login screen. I software restarted and it booted to the log in again, including chime.
                      I then disconnected the battery to see if it would now boot on charger power only, but it did not -- same behaviour as before (shows the low battery screen, then shuts down).
                      I then reconnected the battery and found that not only does it no longer boot, now it won't take any current at all (e.g. no low battery screen). Very confusing, but this is the old swollen battery so perhaps not surprising it is flaky.
                      It's dawned on me that there might be two separate issues going on -- the fact that it won't boot on charger only might be due to the liquid damage years ago (which fried one of the usb ports). A good battery might be all it needs.
                      Regarding the measurements you recommended, I'll have to get some finer voltmeter probes. Did you mean to connect the main battery power (J6950), connect the usb charger, and measure the pins on J6951?
                      • mon2
                        • 14814
                        Yes, J6951 pins 2 & 3 to ground voltage for each.
                        • ipmungam
                          • Nov 2021
                          • 16
                          Thanks. Replacement battery has arrived, but I haven't installed it yet -- hoping to understand what's going on before possibly ruining another one.
                          With
                          the old (swollen but sort of working) battery connected at J6950
                          USB power connected (through the one good port)
                          the ribbon cable that goes into J6951 disconnected
                          the voltages at pins 2 & 3 of J6951 (on the board) are both 3.4V.
                          As before, it negotiates 20V goes through what we called phase 1 above, and in phase 2 now power cycles between 0 and 250mA -- I assume trying to charge the battery.
