water-damaged iPad 7
  • ApplePie14
    • Dec 2024
    • 24
    • JAPAN
    iPad 7 won't turn on.
    When I connected the DC power supply and turned on the switch, the current rose to around 70 mA, then dropped to 0 mA, and then rose again to around 70 mA, repeating this cycle.
    The voltage was normal, including the secondary voltage.
    Could the cause be the CPU?
  • GeirAndersen
    iPad .pcb file collection
    by GeirAndersen
    I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
    Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
    IPAD COLLECTION 1
    +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
    +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
    +---iPad mini3 820-00008(A1599) 820-00002(A1600)
    +---iPad mini4 820-00180(A1538) 820-00177(A1550)
    +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
    +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
    12-09-2024, 09:28 AM
  • grimacelord
    Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
    by grimacelord
    Hello.
    Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
    If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
    For example, when I connect the iPad to...
    04-15-2022, 11:06 AM
  • trepachka
    iPad Air A1475 Boot loops after replacing battery
    by trepachka
    This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
    The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
    I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
    11-08-2024, 03:17 PM
  • SarcasticOP
    iPad Pro 12.9 (6th Gen) screen shuts off after unplugging device
    by SarcasticOP
    Greetings,
    I have an iPad Pro 12.9" 6th gen tablet that had a screen replaced about 10 months ago at a repair shop and last week the screen went blank during use. The device was still on, notifications played sound for example. I have replaced the screen twice, both screens are working until I unplug it, at which point I can see that screen is on but is all black. If I press the power button, the backlight goes off, and when I press it again, the image appears for half a second and then the screen goes back to being black but on. This issue is not present at all when the iPad...
    10-24-2024, 11:55 AM
  • mon2
    ipad Pro A1876 not charging - FIXED
    by mon2
    Hi. Thought to share a recent repair on the iPAD PRO A1876 that was flaky / not charging.
    Issue was a defective dockflex charge cable.
    See attached pix on the original connector condition.
    Sourced a fresh cable from here:
    https://www.esourceparts.ca/replacem...ad-pro-11.html
    After the replacement - the display was dark and we almost were in a panic. The charge current was around 40mA @ 5V which is too low for this unit. Confirmed...
    04-28-2021, 12:39 PM
