Lenovo Y50-70 only charges when turned off.
This topic has been answered.
  • Darren Hibbert
    • 116
    I have a Y50-70 gaming laptop. It has a problem where it charges up fine when the laptop is off, but when it's on, it doesn't.
    I've tried a new 135w charger + new Lenovo battery and a new charging port but it made no difference.
    I've updated all the drivers and still no difference.
    Could it be down to a dodgy chip? I'll see if i can find a schematic and someone on here might be able to direct me where to test
    Many thanks in advance.
  • Answer selected by Darren Hibbert at 08-10-2025, 09:27 AM.
    Darren Hibbert
    • 116
    I found the problem. Somebody had previously changed the charging port. However on closer inspection and with help from a boardview, the manafacturer of the port had wired it incorrectly. One of the ground wires was wired where a data line should have been and the data line was wired into where the ground should have been. Charging perfectly now
    • mon2
      • Dec 2019
      • 14630
      The Lenovo Y50-70 laptop charging only when turned off indicates a potential issue with the power management settings or a hardware problem. It could be related to the "fast startup" feature, the power management settings within Lenovo Vantage, or a hardware problem with the battery or charging port.
      Here's a breakdown of potential causes and solutions:
      1. Fast Startup:
      • Fast startup can sometimes interfere with charging when the laptop is off.
      • Solution: Disable Fast Startup in Windows power options: Go to Control Panel > Hardware and Sound > Power Options > Choose what the power buttons do > Change settings that are currently unavailable > Uncheck "Turn on fast startup".
      • Darren Hibbert
        • 116
        Turned fast startup off, same problem.
        • mon2
          • Dec 2019
          • 14630
          https://forums.lenovo.com/t5/ThinkPa...ly/m-p/4483670
          • Darren Hibbert
            • 116
            Thanks for that. Unfortunately my laptop is not in airplane mode so the problem continues. I think it's probably a motherboard issue which I'd like to get to the bottom of.
            • mon2
              • Dec 2019
              • 14630
              Enter the BIOS - what are the stats of the mated power adapter?
              3. Locate AC adapter information
              • Within the relevant section, look for entries such as "AC Adapter," "Battery Information," or "Power Management".
              • You may see information about the AC adapter's status (detected, not detected) and possibly its wattage.
              • Darren Hibbert
                • 116
                • mon2
                  • Dec 2019
                  • 14630
                  Very nice. Most adapters are intelligent now. The bios often can serve as a confirmation of what the logic sees or does not see. Suspecting that the adapter was assumed to be under rated due to missing adapter ID line.
                  • coasterghost
                    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                    by coasterghost
                    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                    System Hardware:
                    Processor: AMD Ryzen 7 PRO 5850U
                    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                    09-08-2025, 10:46 PM
                  • BMCappelletti
                    Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                    by BMCappelletti
                    Hi everyone.
                    Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                    Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                    Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                    02-18-2025, 12:22 PM
                  • motormayhem
                    Lenovo T460 Only Charges on One Charger
                    by motormayhem
                    Laptop Question
                    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                    05-12-2023, 01:46 PM
                  • shahnld
                    Lenovo legion 5 pro startup issue
                    by shahnld
                    Good day Experts
                    I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                    A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                    And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                    08-24-2025, 12:31 PM
                    Lenovo 3000 Series Schematic
                    Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                    3000 C100 laptop with Braille keyboard
                    Lenovo 3000 C
                    C100, C200 - 15-inch XGA screen
                    Lenovo 3000 N
                    N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                    N500 - 15.4 inch screen.
                    Lenovo 3000 V
                    V100, V200 - 12.1-inch WXGA models
                    Lenovo 3000 G
                    G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                    10-04-2024, 06:05 AM
