LENOVO THINKBOOK 15 G4 missing +20V_VIN
  • mferna14
    • Jun 2018
    • 1038
    Dear friends. I am working on a LENOVO THINKBOOK 15 G4 IAP Motherboard No: LA-L931P REV 01. The motherboard turns ON fine with or without battery & AC power, & battery charging is good too. This is for the first time till the power adapter is plugged in. When Laptop is in ON position, as soon as I remove the USB-C main power & plug it back again +20V_VIN is no longer there (Missing) & battery does not charge at all., I thought that the TPS65994-AE Chip was bad., so replaced it with a new good chip, but the problem is still there. On the battery charging chip BQ25710 where pins (VBUS,ACN & ACP) should have the +20V_VIN, all gone. Then I have to remove the battery again to getting the motherboard working & having the battery being charged again. I had a good test battery for this model, but still the same problem. If some repairs tips are offered, it would make the trouble shooting much easier. Schematics & Boardview both available here. Thanks in advance.
  • mon2
    • Dec 2019
    • 14513
    Review the mosfets on the attached page. Each is a suspect. Remove all power. Meter in resistance mode. Measure the resistance across each of the DCin mosfets:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Each measurement must be hundreds of k ohms or higher else is a suspect and part may be defective.
    • mferna14
      • Jun 2018
      • 1038
      Thanks mon2 for the tips., I checked all the 4 MOSFET & all were 100% ok. Upon more trouble shooting, found that this chip gets very hot, it the 5VALW chip & the number printed on the chip is QrFHB. I have this chip in stock SY8386BRHC (Qq). Is this chip the same as SY8386CRHC (Number printed on the schematics)??? or I have to find the correct chip SY8386CRHC. I was checking AE, I could not find this number. Thanks dear
      • mon2
        • Dec 2019
        • 14513
        Hi. How is the great weather there? Crazy hot here.
        No - cannot replace theSY8386CRHC with SY8386BRHC - there are differences. Measure the resistance to ground of the output of the SY8386CRHC.
        Pins # 12 & 13 do not match between the 2 different parts.​​
        • mferna14
          • Jun 2018
          • 1038
          mon2., It's like placing a Hot HEATER in front of us. All of a sudden 18 days of continous heat, hope does not last for long.
          The resistence of both the pins 11 & 12 are in Mega ohms (Chip Removed). Actually how I found this chip being defective, there was a short on all input caps & this chip getting hot. I removed the caps first but the short was present. Once I removed the chip, short gone. Hopefully this chip is defective. I found the Chip Qr on AE, easily available. I will order it today. Thanks for the help till the chip comes in. TC
          • mferna14
            • Jun 2018
            • 1038
            mon2., good day. I received this chip SY8386CRHC., the short is gone, no more shorts on the caps. But till now the battey is not charging... I checked nearly every component on the charging rails, all seem to be good, no problem at all. Where could be the problem seeing the schematics. Can you please give me some tips. Thanks dear
            • mon2
              • Dec 2019
              • 14513
              Can you confirm which IC was replaced on the board?
              For PU501, the part number showing in my database of schematics is SY8388C3RHC.
              • mferna14
                • Jun 2018
                • 1038
                Yes this is the same IC SY8386CRHC which was replaced..... It's Qr... which is the same # on the OLD & new chip... Now at least 5v is stable & the chip does not get hot at all.
                • mon2
                  • Dec 2019
                  • 14513
                  Remove all power. Disconnect the battery. Measure the resistance between pins SRN & SRP (19 & 20) directly on the charger IC.
                  What is the full path resistance of the battery charger leg?
                  Measure the resistance across the mosfet pins of:
                  battery mosfet @ PQB13
                  source / drain
                  source / gate
                  gate / drain
                  Repeat for PQB2 but note that this is a dual mosfet in a single package so review the pinout for same measurements.
                  • wraster
                    Laptop stays on for only ~10sec when battery is connected, fine otherwise (Lenovo ThinkBook 15 G4 AMD)
                    by wraster
                    I have a Lenovo ThinkBook 15 G4 AMD (HLXB5 LA-M062P) that, when the battery is connected, starts up and shuts off in about 10 seconds, even when connected to power supply via USB-C charger. When the battery is disconnected, the computer stays on as in normal/expected operation (powered by USB-C charger input). I bought a new battery and see the exact same thing. My conclusion is it is not the battery itself but maybe some circuit or component involved in battery/DC-in crosstalk. I found a schematic but not boardview (request link below - sorry for the formatting, I'm not sure how to make an inline...
                    Hi, I have a TB 15 Gen 4 that has an issue with the battery circuits. I believe the schematic is the same as this one: https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/schematic-requests-only/3522169-lenovo-thinkbook-14s-yoga-gen2-la-m062p
                    02-25-2025, 11:33 PM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • TecnicaNTT
                    Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                    by TecnicaNTT
                    I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                    My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                    I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                    I am now asking here for help if anyone knows how to do this in...
                    09-20-2024, 08:10 AM
                  • code share
                    Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                    by code share
                    I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                    Here's what I've tried so far:
                    • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                    • Booted successfully on AC power only with the battery disconnected
                    • Visual inspection of the battery — no swelling, burn marks, or connector damage
                    • Battery
                    04-21-2025, 12:50 PM
                  • thxd43
                    Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                    by thxd43
                    Hello, first of all, excuse me, I am using the translator, English is not my native language.
                    I have a Lenovo ideapad 330S - 14IKB laptop.
                    The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                    02-23-2023, 08:37 PM
