Lenovo Legion 5 Y540-15IRH IT8226E-192 shorted
  • MicroSMD Lab
    • Sep 2018
    • 145
    • Trinidad and Tobago
    Hi, I'm working on a Legion 5, NM-C221 Rev. 2.0 board. Charging port replacement butchered by other shop and EC took a hit. I ordered replacements from China (shums) soldered it on and nothing happens, no lights. It does get 3.3V bot no 5V, draws 50mA. I read on another thread (Lenovo y540-17IRH IT8226e-192 - Badcaps) that it should auto-program but I'm not sure how that process works, should I wait 30s, 1min... then lights will come on, do I need to flash a particular bios or is there something else wrong with the board? Any assistance is much appreciated, thanks.
  • Sephir0th
    • Oct 2020
    • 1289
    It could mean that a even more critical issue was overlooked.
    So what's working and what not right now, in detail? 50mA is a really parasitic consumption. A dead chipset should be ruled out.
    And of course issues caused while soldering the replacement EC (bridges/shorts/cold joints/etc.)
    FairRepair on YouTube
    • MicroSMD Lab
      • Sep 2018
      • 145
      After soldering the EC I usually push each pin to make sure it's soldered properly and I check for shorts between adjacent pins with beep mode, I go through each pin first testing continuity from the pin to the pad then checking for short to the adjacent pin and keep walking the probes down. As for the PCH, with the thermal camera, it's the only thing heating up when I apply power but it's uniform heating so I'm not sure the PCH is dead... unless it's not supposed to heat up or is there a way to test the PCH? I haven't gone through the power sequence yet... still looking for it on the schematic.
      • dbuergi
        • Jul 2024
        • 138
        • Deutschland
        Hi Buddy,
        did you solve your problem? Same situation here. I ordered a EC replacement from AliExpress and now stuck at 19v and 0,05a.
        • dbuergi
          • Jul 2024
          • 138
          • Deutschland
          Hi Buddy,
          • reformatt
            • Feb 2020
            • 1535
            When I have replaced EC's on Lenovo's, they need programming with a tool like SVOD4. They don't auto-program from BIOS AFAIK.
            • dbuergi
              • Jul 2024
              • 138
              • Deutschland
              No need for programming on this model. You can find a thread at badcaps which confirms it and there are several videos.
              • khaahk
                • Dec 2013
                • 820
                • Estonia
                If the replacement ec is empty then yes but the ones from aliexpress are used and not empty so they might not reprogram itself.
                • dbuergi
                  • Jul 2024
                  • 138
                  • Deutschland
                  Ah okay, got it. Do you know a trustworthy source where i can buy a new chip?
                  • reformatt
                    • Feb 2020
                    • 1535
                    I buy from SUHMS on AliExpress with never any issues. I've had fake or counterfeit parts off other sellers so just stick with SUHMS.
                    • khaahk
                      • Dec 2013
                      • 820
                      • Estonia
                      All the parts from SUHMS are used, last time i ordered (will be the last time also) i received a shorted ec from them. (One vcc pin was shorted even before powering up - they required me to prove it in dispute ). Buying from aliexpress is a lottery and if you get a new EC that is probably like winning a jackpot.
                      • dbuergi
                        • Jul 2024
                        • 138
                        • Deutschland
                        So you know any other source? I know a shop in Germany but he showed a YouTube video where i replaced the chip and told that it doesn't need programming. But he sells "programmed" chips for 44 Euro.
                        • khaahk
                          • Dec 2013
                          • 820
                          • Estonia
                          No. If you have to do it once then buy the 44 EUR preprogrammed EC, otherwise buy the programmer - it will pay off in short time. Used parts you buy more than needed in case some don't work.
                            • 22123
                            One of these cheap programmers might do the job https://www.aliexpress.com/item/1005007682301217.html
                            • reformatt
                              • Feb 2020
                              • 1535
                              I don’t disagree that it’s a lottery but so far I’ve had good success with them. Every Chinese supplier will do the dodgy on you at some point. Results vary.
                              • dbuergi
                                • Jul 2024
                                • 138
                                • Deutschland
                                Could you post a Screenshot or name of the programmer? Cant open the link because of my region.
                                  • 22123
                                  The name in the title is ITE Lianyun EC Read/write Burner Programmer
                                  • dbuergi
                                    • Jul 2024
                                    • 138
                                    • Deutschland
                                    So now i have my empty chip but still the same fault. Only the PCH shows some heat up to 30c. Pressing the power button doesn't change anything. So 19V and 0,05A.
                                    Is there any way to measure if the PCH is dead or anything else?
                                    • khaahk
                                      • Dec 2013
                                      • 820
                                      • Estonia
                                      How do you know it is empty?
                                        LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                        This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                        09-12-2024, 02:30 PM
                                        Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 05:00 AM
                                        Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 04:10 AM
                                        LENOVO Legion T730 Legion i9-9900K Specification for Upgrade or Repair
                                        This specification for the LENOVO Legion T730 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion T730 boardview and Legion T730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
