Macbook Pro M1 (A2338) 820-02020 not charging.
  • Gueric
    • Feb 2025
    • 72
    • France
    I returned home from college. My MacBook battery was flat. Plugged it in. Nothing. Won’t boot. Waited for an hour. Nothing.
    When plugging the charger : 20v at 0.02 amps.
    pressing any key will make the « low battery » icon show up. Then switch to 5v and 420mA constant. Trackpad clicks, keyboard works.
    Decided to put the board into another M1 body with a charged battery, it’s booting perfect, still 5v and 420mA tho, and battery is not charging.
    I diode moded every pin of U5200 and they’re all fine. I know very little about Apple silicon machines so any help would be appreciated.
    hey Mon2. I hope you’re doing fine.
    edit : basically : in the Mac that still has some juice, board boots fine, works fine, battery percentage is showing, but no charging at all, and board won’t pull more than 5v 420mA.
    inside my actual Mac it wont boot at all since the battery is flat and charging system is defective.
  • mon2
    • Dec 2019
    • 14209
    Hey
    Attach the power adapter. Carefully, confirm the voltage to ground of:
    PP1V8_S2 ; @ C5280
    PPCHGR_VDDA ; @ C5275
    PPCHGR_VDDP ; @ C5277
    Post the voltage for each.
    Next, remove all power. Meter in resistance mode. Measure the resistance across CHGR_CSI_FILT_P & CHGR_CSI_FILT_N. You can measure these via probes on C5221 & C5222. We are checking the input resistance path for the current sense circuits that power U5200. Post the resistance in ohms.
    • Gueric
      • Feb 2025
      • 72
      • France
      PP1V8_S2 is exactly 1.800v.
      PPCHGR_VDDA and PPCHGR_VDDP are both 5.175v.
      Resistance across C5221 and C5222 is 02.75 ohms.
      By the way, if that can help, even though the board is working fine at 5v and no charging, bare board pulls 5v and 190mA, then drops to 0.00A after 2-3 seconds.
      and originally this Mac had a defective slave CD3217 (might not be relevant to this charging issue, but I wanted to add this detail)
      thanks mon2 :-)
      • mon2
        • Dec 2019
        • 14209
        Review the cd3217s: (see details)
        https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
        Review the battery charge resistance path on the isl9240. With no power.
        • Gueric
          • Feb 2025
          • 72
          • France
          mon2 are you sure a CD3217 could be defective if the Mac fully works except for the « battery not charging » part ?
          Even though yes, it’s stuck at 5v, but it negotiates 20v at first when plugged in for the first few seconds and drops to 5v when interacting with it (pressing any key or even the trackpad)
          • mon2
            • Dec 2019
            • 14209
            I think the CD3217 are ok. You can test all the permutations of the controller (flip by 180 degrees etc) to see if that makes a difference. It is a positive sign that 20v is selected but if it is resetting then some trigger is causing this fall back. The CD3217 tests are to confirm the LDO rails are ok on the pd controller. Do you own a thermal camera? If yes, check if any part is thermal throbbing in the camera.
            I recall reformatt observing that Q5230 is a point of failure.
            Remove all power. Meter in resistance mode. Measure this DUAL mosfet using resistance mode checks:
            source / drain
            source / gate
            gate / drain
            Checking for a low resistance of the mosfet. Note again, this is a DUAL mosfet. No power during the resistance checks.
            • Gueric
              • Feb 2025
              • 72
              • France
              Okay well you were right. The board behaves exactly the same no matter the port and USBC orientation EXCEPT for one orientation, when plugged one way into the master CD3217 (the one i didnt replace). The ampmeter doesn’t even turn on and PPBUS is 2.7v, dropping to 1.5v after a few seconds. Tried without the ampmeter and same result. Boards works with 3 out of the 4 possible « connections» Turning the USBC around makes it work fine.
              What does this even mean? Is it a CD3217 issue or something else ?
              also some details : i never replaced the master CD3217. I replace the slave, which works perfect in either orientation. The board never had water damage and i didnt replace anything else.
              thanks mon2
              • mon2
                • Dec 2019
                • 14209
                Do not have a whole of experience with the PD controllers (yet) but can state that cross shorts are a real thing. I am also on reddit forums and see daily reports of 'defective motherboards' that will not charge. Such a nasty design.
                Start with removing the USB-C paddle board(s). Clean off the contacts with IPA to be sure they are without any debris. Do inspect the side that is posing the fault you noted. Does it look dirty? Damaged contacts? A good tool we use is the Qianli tail tester which is under $20 USD and is a quick way to test the USB-C ports (both sides) + acts like a USB-C power meter. Nice design of a product.
                From the articles by piernov and others - if one pd controller is not working, the group will fail to function. Suspecting that the side with the failing USB-C port is the root cause of your problems. Since you are working with a M1 - the sourcing of a valid replacement may be an issue. I do believe you will need to source a replacement that is from the same logic board and from the same location for the donor component. This is because each such controller has its own address and different firmware in rom. Certainly correct me if you find otherwise.
                • Gueric
                  • Feb 2025
                  • 72
                  • France
                  Hey mon2 im back. I did a few measurements, and tried measuring voltage with the misbehavingCD3217 plugged in. When plugged in the way that doesnt even turn on the ampmeter, measuring PPDCIN_USBC_AON gives me 0v. PPBUS_AON gives me around 2,7v then slowly drops below 1v overtime. PPDCIN_AON_CHGR_R give me a few milivolts at most.
                  I think I’m with you on this one. I tried cleaning the port as best as I could, try with a different USBC flex cable, nothing worked.
                  honestly I don’t have enough experience to point at anything except this master CD3217 chip. Thankfully I have one laying around from this same position and same board number. I don’t really know what to try or measure other than replacing the chip itself.
                  This whole experience allowed me to discover that M series machines can boot from a 5v input and a potential defective USBC controller.
                  what do you think ? Is there any other option or location to measure voltages or resistance from before attempting a replacement ?
                  mon2
                  • Gueric
                    • Feb 2025
                    • 72
                    • France
                    Also, it’s a standard M1 Pro from 2020. Only 2 ports and thus 2 CD3217s.
                    • Gueric
                      • Feb 2025
                      • 72
                      • France
                      Sorry important correction : PPDCIN_CHGR_CHGR_R is around the same voltage as PPBUS_AON when plugged in the bad way (around 2v, dropping fast)
                      measuring on the fuse just next to the CD3217s never gives me more than 100mV. (When plugged in the bad way into the master CD32)
                      okay some news… what the hell.
                      Both ports randomly decided to negotiate 20v again?
                      still, on the master CD3217 ports, it won’t work when plugged the « wrong » way. But the other way it does negotiate 20v aswell. Bruh. All I did was heating the master CD3217 for a few seconds at 150c then waited for a few minutes.
                      • Gueric
                        • Feb 2025
                        • 72
                        • France
                        Some news again… mon2
                        So the CD3217 port i replaced originally is now rebooting sometimes, and the other port works but only in 1 orientation and doesn’t reboot.
                        so i decided to put the machine back together. It is pulling 20v and 2.4Amps, so way better.
                        tried powering it on, it works, but acts strangely on the login screen. After a few seconds on the login screen, it reboots, boots to the login screen, and 5 seconds after reboots again. I really don’t know what to do at this point this whole thing is about to make me quit
                        right now i turned the machine off and closed the lid and it appears to be charging, 20v at 2.4A.
                        • mon2
                          • Dec 2019
                          • 14209
                          Allow it to charge for a few hours then test again. Also try to boot from internet to rule out a corrupt OS at this time.
                          Steps to Boot from Internet Recovery
                          1. Restart the MacBook: Click the Apple logo and select Restart.
                          2. Hold Command + Option + R: Immediately press and hold these keys until you see a spinning globe.
                          3. Connect to Wi-Fi: If prompted, select a Wi-Fi network and enter the password.
                          4. Wait for the Recovery Mode: The Mac will connect to Apple’s servers and load the recovery tools.
                          • Gueric
                            • Feb 2025
                            • 72
                            • France
                            Okay so mon2 i let it sit for around 3 hours, until the current draw dropped to 1A. Upon opening it it seemed to have been completely corrupt somehow, my password wasn’t recognized, keyboard was misbehaving, and after going into the startup options it couldnt speak with apple Activation servers. I had to manually erase the mac to get it to activate, and now it’s currently reinstalling MacOS. Oh my freaking god.
                            and still one of the 2 ports isn’t working at all now. Crazy. If the Mac fully works ill stick to just 1 port.
                            • rounin
                              MacBook A2338 M2 (820-02773) Not Charging
                              by rounin
                              Post:Hello everyone,I'm troubleshooting a MacBook A2338 M2 (820-02773) motherboard with a charging issue. Here’s the situation:Initial Fault:
                              • L8430 was burnt. After replacing it, the system worked normally for about two weeks, then failed to power on.
                              Current Symptoms:
                              1. Without Battery:
                                • When connected to power, voltage ramps from 5V to 20V, then drops back to 5V, cycling repeatedly.
                                • After disconnecting F5200, USB-C voltage stabilizes at 5V, and Pin 1 of F5200 measures 12V.
                              2. After Replacing U8100:
                                • With the battery connected, the system powers on normally, and the battery icon displays
                              Yesterday, 11:24 PM
                            • bibinskii
                              Macbook Pro M1 (A2338) - Not Charging but Detected and Post
                              by bibinskii
                              A client showed up with a Macbook Pro M1 stating that the battery doesn't get charged (no increase in percentage) but still charge. She left me with the battery 25% and still draining. The Macbook is fully functional. I checked with coconut battery and system report. Battery health shows 85% and stating normal condition, no abnormalities. When it is charging, the system says it takes 10 hour to finish charging. I went ahead to charge it for a longer period, the battery just drains (doesn't get charged).
                              At first, I thought that this must be a battery issue. I went to replace the battery....
                              07-22-2024, 12:22 AM
                            • flat-earther
                              ASUS X54H laptop thinks it's always charging even with charger unplugged
                              by flat-earther
                              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                              Windows also shows ''Plugged in'' when charger is not connected.
                              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                              If I let battery run out and say it has 3% Windows will...
                              06-24-2025, 09:32 AM
                            • drlarsen
                              MacBook Air M1 A2337 battery/charging issue
                              by drlarsen
                              Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                              I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                              On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                              After some hours, the battery status did not improve. Restore via DFU did not help.
                              I connected the power adapter to a Kill-a-Watt...
                              07-17-2025, 02:35 PM
                            • robka
                              MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                              by robka
                              my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                              I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                              The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                              After that the Macbook was dead. It isn't charging anymore.
                              The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                              03-02-2024, 02:58 PM
