Request for Help – ASUS G531GW Rev 1.6 – No Power On
  • conghuyms
    • Apr 2022
    • 31
    • Vietnam
    I need your support with an ASUS G531GW Rev 1.6 laptop.
    When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
    Here’s what I’ve checked so far:
    • Motherboard has been removed for inspection.
    • 3V and 5V always-on rails are present (3V/5V_ALW).
    • 1.8V and 1.09V at the PCH are present.
    • I don’t have the boardview/schematic, so troubleshooting is limited.
    • I tried checking the power button signal from the keyboard connector (embedded power button design).
      • Only two pins show voltage:
        • Pin 4 from the left has 2.47V
        • Pin 5 from the left has 3.2V
        • Upon applying power, the measured current consumption is 0.04 A
      • All other pins have no voltage.
    I'm unsure what to check next from here. Could this be an EC (Embedded Controller) or PCH issue? Or is there something else I should verify?
    Any guidance would be greatly appreciated. Thank you in advance!
  • mon2
    • 14156
    Remove all power. Meter in resistance mode. Measure the resistance to ground of each inductor. Checking for low resistance which may indicate a short on that buck regulator power rail. Post any suspects.
    • conghuyms
      • Apr 2022
      • 31
      • Vietnam
      "I have measured all the inductors as you instructed. Only the GPU and CPU inductors have low readings, but I believe they are still within the acceptable range. Right now, I feel stuck and don’t know where the root cause is. Please help me. Thank you very much."
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • meraklinetx
        Asus Z97-a power cycle, no boot no cpu voltage
        by meraklinetx
        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
        05-10-2023, 06:08 AM
      • Duranitron
        Asus x512dk rev 2.1 power on problem
        by Duranitron
        When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
        Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
        11-26-2024, 10:22 PM
