Original Data for T2 ROM Chip Macbook Air A1932 820-01521-A
  • PACh
    • Feb 2022
    • 24
    • Austria
    Hello, im looking for the Original Data for the T2 ROM Chip for a Macbook Air A1932 820-01521-A
    The one I saved gives me an error in the verify phase, when I install it back the macbook stays in DFU mode…
    Thanxs in advance
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • Loki_Fido
    Requesting help identifying chip in Macbook Pro A2485
    by Loki_Fido
    Hi ya folks,
    I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
    It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
    I replaced it and the SSD are fine. No more shorts.
    But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
    But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
    Chip marking...
    08-07-2025, 10:17 PM
  • SSBDADC234
    MacBook Pro 14". The screen DP chip failed.
    by SSBDADC234
    When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
    However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
    Testing the chip pins with a multimeter revealed a short circuit inside the chip.
    Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
    04-19-2024, 08:51 PM
  • bouch
    unlock macbook air A1932 2019
    by bouch
    hi
    i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
    i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
    i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
    have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
    I need help or information?
    Does anyone have the minat2 activator 1.4 software?
    Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
    Thank yo...
    03-12-2025, 10:14 AM
  • som_b1
    Macbook pro T2 chip change
    by som_b1
    Hello. I'm interested in this topic)) - will the T2 chip from the MacBook Pro 13 fit the MacBook Pro 16 of the same year, the same SSD size? Maybe someone has tried it?
    11-05-2025, 12:11 PM
