Lenovo Legion 5 Pro 16ACH6H Water Damage
  • Andreasbest
    • Aug 2014
    • 1177
    • Hellas ( Greece )
    Originally posted by mon2
    Test the resistance across the 2nd dcin mosfet.
    source / drain
    source / gate
    gate / drain
    often 2nd dcin mosfet is defective and takes down the 1st dcin mosfet since they share the gate pins.
    no power to the board during these tests.
    S - D 7ΜΩ
    S - G 7.19ΜΩ
    G - D 12ΜΩ
    With mosfet soldered on board.
    • khaahk
      • Dec 2013
      • 781
      • Estonia
      I was wrong about the work from battery, from the datasheet we read :
      7.3.1.1
      Battery Only
      When VCC voltage is above UVLO, bq24780S powers up to turn on BATFET.
      This is the PQ5403 on schematic, it connects the battery voltage to B+.
      So this mainboard does not work without the charger ic.
      Originally posted by khaahk
      I don't know no checks that can be done, it is ic-s internal fault. If mainboard has no further problems then it probably should work from battery.
      • Andreasbest
        • Aug 2014
        • 1177
        • Hellas ( Greece )
        So i must order a new PU5401 to replace it and test it again, correct?
        • khaahk
          • Dec 2013
          • 781
          • Estonia
          Yes
          • Andreasbest
            • Aug 2014
            • 1177
            • Hellas ( Greece )
            Ok, ordered 5 pieces. When they come i'mm come back with results
            • funnypenguin
              GenuinelyTrying
              • Aug 2025
              Sorry to jump in on this one. I'm working on the same laptop that seems to be going through the same thing, no signs of life. Here's what I have so far. If anyone has any ideas or input I would be super greatful! I'm thinking maybe get a new 24780s?
              Resistances
              DC in MOSFETS
              PQ5401, gate source drain no shorts
              PQ5402 gate source drain no shorts
              Main Power Rail to Ground 3 Mega Ohms
              Current sensing lines
              AC input current sensing amp inputs .7 ohm
              Batt Current sensing amp 20 ohms
              ACOK (pin 5) to ground .47 MegaOhms
              Voltages
              Main Power Rail Check
              @ PR5401 Fluctuating 3.1-3.3v, not fully shorted.
              Charger IC voltages
              REGN (pin 24) 6.04v
              VCC (pin 28) 19.7v
              ACDET (pin 6) 2.62v
              - TI manual says greater than 2.4v should be ok?
              CMSRC (pin 3) .03-.35v
              - Should be close to AC? something wrong?
              ACDRV (pin 4) .02-.35v fluctuating with CMSRC and Main Power Rail.
              ACOK (pin 5) 0v
              • Andreasbest
                • Aug 2014
                • 1177
                • Hellas ( Greece )
                #27
                Replacements of charger ic arrived, you want to replace it and try if it power on OR you want to take any measurements before I connect power?
                • khaahk
                  • Dec 2013
                  • 781
                  • Estonia
                  #28
                  Make the replacement, if there are any problems then take measurements, with liquid damage everything is possible.
                  • Andreasbest
                    • Aug 2014
                    • 1177
                    • Hellas ( Greece )
                    #29
                    Sorry for the delay, got a problem.
                    Here are the measurements:
                    PR5401 16Ω on both pins to GND
                    PU5401 voltages:
                    pin5 0v
                    pin6 2.68v
                    pin24 6v
                    pin28 30v
                    Just replaced it.
                    Still no power, voltages the same, except the pin 6 now gives 0.5v
                    Replaced it with 24780 not 24780S, this is what the supplier sent me and as i read here it's compatible.
                    • khaahk
                      • Dec 2013
                      • 781
                      • Estonia
                      #30
                      I don't know why but somehow i missed the PR501 ohms reading on your original message. This means that you have low ohms on main power rail B+, meaning you might have some high side mosfet failure or some component failure on main power rail. Why is pin6 low - maybe bad connection or bad chip. Try to measure resistance to gnd on all coils - try to find the 16 ohms reading which might indicate the failed part. For now you can ignore the PU5401 - first you need to deal with the main power rail.
                      • Andreasbest
                        • Aug 2014
                        • 1177
                        • Hellas ( Greece )
                        #31
                        PL1009 has the same resistance to GND as PR5401.
                        Plus i get beep when i connect probes to PL1009 and PR5401, seems they are in same rail.
                        • khaahk
                          • Dec 2013
                          • 781
                          • Estonia
                          #32
                          Then PQ1005 is a suspect, remove it and see if resistance on PR5401 goes higher. If so then the PQ1005 needs to be replaced, hopefully the cpu survived the failure, resistance reading gives some hope but ...
                          • Andreasbest
                            • Aug 2014
                            • 1177
                            • Hellas ( Greece )
                            #33
                            Removed PQ1005 and now the resistance on PR5401 is several KΩ. So i replace it and resolder back the old 24780s?
                            • khaahk
                              • Dec 2013
                              • 781
                              • Estonia
                              #34
                              Probably the old 24780s is good, do you have a replacement for PQ1005? - it is a dual mosfet.
                              At the same time you can make resistance measurements on PU1006 pin 3,7 and 8 to gnd, looking for abnormal low resistance, it might be damaged due to PQ1005 being shorted.
                              • Andreasbest
                                • Aug 2014
                                • 1177
                                • Hellas ( Greece )
                                #35
                                3 16K
                                7 7.2K
                                8 10k
                                I'll solder back the old charger ic as i trust it more than the chinese replacement, not sure about MOSFET, i'm checking on donor boards now.
                                Found several Z998 they look compatible, can you confirm please?
                                • khaahk
                                  • Dec 2013
                                  • 781
                                  • Estonia
                                  #36
                                  Layout is a little different, also less powerful. Try to find some other options.
                                  • Andreasbest
                                    • Aug 2014
                                    • 1177
                                    • Hellas ( Greece )
                                    #37
                                    Checked 12 motherboard. not able to found this or anything compatible, very powerful and dual mosfet, rare.
                                    Ordered some, i'll get back when they arrive. I think this was the cause of the problem and i hope CPU is not damaged.
                                      Lenovo NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P Notebook Specification for Upgrade or Repair
                                      This specification for the Lenovo NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P boardview and NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-07-2024, 04:10 AM
                                      Lenovo Legion 5 Pro 16ACH6H Notebook Specification for Upgrade or Repair
                                      This specification for the Lenovo Legion 5 Pro 16ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 Pro 16ACH6H boardview and 5 Pro 16ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-07-2024, 04:30 AM
                                      LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                      This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                      09-12-2024, 02:30 PM
                                      Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                      This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-07-2024, 05:00 AM
                                      Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                      This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
