Lenovo Legion 5 Pro 16ACH6H Water Damage
I was wrong about the work from battery, from the datasheet we read :
7.3.1.1
Battery Only
When VCC voltage is above UVLO, bq24780S powers up to turn on BATFET.
This is the PQ5403 on schematic, it connects the battery voltage to B+.
So this mainboard does not work without the charger ic.
Sorry to jump in on this one. I'm working on the same laptop that seems to be going through the same thing, no signs of life. Here's what I have so far. If anyone has any ideas or input I would be super greatful! I'm thinking maybe get a new 24780s?
Resistances
DC in MOSFETS
PQ5401, gate source drain no shorts
PQ5402 gate source drain no shorts
Main Power Rail to Ground 3 Mega Ohms
Current sensing lines
AC input current sensing amp inputs .7 ohm
Batt Current sensing amp 20 ohms
ACOK (pin 5) to ground .47 MegaOhms
Voltages
Main Power Rail Check
@ PR5401 Fluctuating 3.1-3.3v, not fully shorted.
Charger IC voltages
REGN (pin 24) 6.04v
VCC (pin 28) 19.7v
ACDET (pin 6) 2.62v
- TI manual says greater than 2.4v should be ok?
CMSRC (pin 3) .03-.35v
- Should be close to AC? something wrong?
ACDRV (pin 4) .02-.35v fluctuating with CMSRC and Main Power Rail.
ACOK (pin 5) 0vLast edited by funnypenguin; 08-02-2025, 12:10 AM.Comment
Replacements of charger ic arrived, you want to replace it and try if it power on OR you want to take any measurements before I connect power?Comment
Just replaced it.
Still no power, voltages the same, except the pin 6 now gives 0.5v
Replaced it with 24780 not 24780S, this is what the supplier sent me and as i read here it's compatible.
I don't know why but somehow i missed the PR501 ohms reading on your original message. This means that you have low ohms on main power rail B+, meaning you might have some high side mosfet failure or some component failure on main power rail. Why is pin6 low - maybe bad connection or bad chip. Try to measure resistance to gnd on all coils - try to find the 16 ohms reading which might indicate the failed part. For now you can ignore the PU5401 - first you need to deal with the main power rail.Comment
PL1009 has the same resistance to GND as PR5401.
Plus i get beep when i connect probes to PL1009 and PR5401, seems they are in same rail.Comment
Removed PQ1005 and now the resistance on PR5401 is several KΩ. So i replace it and resolder back the old 24780s?Comment
Probably the old 24780s is good, do you have a replacement for PQ1005? - it is a dual mosfet.
At the same time you can make resistance measurements on PU1006 pin 3,7 and 8 to gnd, looking for abnormal low resistance, it might be damaged due to PQ1005 being shorted.
3 16K
7 7.2K
8 10k
I'll solder back the old charger ic as i trust it more than the chinese replacement, not sure about MOSFET, i'm checking on donor boards now.
Found several Z998 they look compatible, can you confirm please?Attached Filesif you find these attachements useful please consider making a small donation to the site
Checked 12 motherboard. not able to found this or anything compatible, very powerful and dual mosfet, rare.
Ordered some, i'll get back when they arrive. I think this was the cause of the problem and i hope CPU is not damaged.Comment
Replaced the PQ1005 and I get power led when I connected power supply, then I installed some ram and the fans to check post and video output but I never saw power led again.
I think the PQ1005 is not soldered firmly, this motherboard need very high heat to melt solder well.
How can I check if PQ1005 is soldered correctly or not?Comment
I solder the FET, the motherboard powered up, i installed heatsink and RAM and never came up again, i see strange voltages the are around 500mV and going up and down, meanwhile i just realized the genuine psu of it is faulty, it has 20v but cannot charge any other Lenovo that i have here. Now i'm using a 170w of mine but still no power.
What do you want to measure?
Incredible mess.Last edited by Andreasbest; 09-15-2025, 08:51 AM.Comment
This specification for the Lenovo NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P boardview and NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 04:10 AM
This specification for the Lenovo Legion 5 Pro 16ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 Pro 16ACH6H boardview and 5 Pro 16ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 04:30 AM
This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...09-12-2024, 02:30 PM
This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:00 AM
This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 05:00 AM
- Loading...
