r540 samsung
  • rickybucalan
    • May 2013
    • 322
    • philippines
    r540 samsung
    good day guys... hope you could help... i got samsung r540 its power up but no diplay with the charger itself. but its work with battery alone. any idea what goes wrong.../
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: r540 samsung
    have you tried using a known good charger?
    • dj_ricoh
      • 2073
      Re: r540 samsung
      what type of connector do you got?
      usually its cable or direct to motherboard.
      when its with cable you got no power to motherboard.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Re: r540 samsung
        I seem to recall that this model has a nec/tokin capacitor on the GPU, that may be the fault. Can you post some pictures of the mainboard? The capacitors will be on the back of the board (the side opposed to the CPU socket and GPU).
        A working TV? How boring!
        • alihomee
          • Dec 2012
          • 1574
          • malaysia
          Re: r540 samsung
          its a tokin issue change it with 4 330 caps
          • dj_ricoh
            • 2073
            Re: r540 samsung
            I just saw the board !
            Tokin!
            even the acting its the same like Toshiba.
            • rickybucalan
              • May 2013
              • 322
              • philippines
              Re: r540 samsung
              thanks a lot guys...
              yes i tried new charger it does the same.
              here i attached some pic but it not so clear sorry for that.
              tokin ic i guess is has it its written 2R0 102 behind of cpu socket.
              so is that i really need to replace for now.
              • alihomee
                • Dec 2012
                • 1574
                • malaysia
                Re: r540 samsung
                yes replace it with 4 caps
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3577
                  • slovakia
                  Re: r540 samsung
                  it looks way smaller with smaller pads ten usual toshiba big token. i dont think he can solder 4x330d on it
                  • rickybucalan
                    • May 2013
                    • 322
                    • philippines
                    Re: r540 samsung
                    can i used nec/tokin 0E128?
                    • dj_ricoh
                      • 2073
                      Re: r540 samsung
                      lol
                      read this
                      https://www.badcaps.net/forum/showth...t=toshiba+lock
                      same problem!
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Re: r540 samsung
                        No, as they degrade quite a bit when being soldered thru normal methods. You'll have the same problem soon. Just use regular tantalum caps.
                          09-07-2024, 05:50 AM
                        • flat-earther
                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                          by flat-earther
                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                          Windows also shows ''Plugged in'' when charger is not connected.
                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                          If I let battery run out and say it has 3% Windows will...
                          06-24-2025, 09:32 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
