r540 samsung
    r540 samsung
    good day guys... hope you could help... i got samsung r540 its power up but no diplay with the charger itself. but its work with battery alone. any idea what goes wrong.../
    Re: r540 samsung
    have you tried using a known good charger?
      Re: r540 samsung
      what type of connector do you got?
      usually its cable or direct to motherboard.
      when its with cable you got no power to motherboard.
        Re: r540 samsung
        I seem to recall that this model has a nec/tokin capacitor on the GPU, that may be the fault. Can you post some pictures of the mainboard? The capacitors will be on the back of the board (the side opposed to the CPU socket and GPU).
        A working TV? How boring!
          Re: r540 samsung
          its a tokin issue change it with 4 330 caps
            Re: r540 samsung
            I just saw the board !
            Tokin!
            even the acting its the same like Toshiba.
              Re: r540 samsung
              thanks a lot guys...
              yes i tried new charger it does the same.
              here i attached some pic but it not so clear sorry for that.
              tokin ic i guess is has it its written 2R0 102 behind of cpu socket.
              so is that i really need to replace for now.
                Re: r540 samsung
                yes replace it with 4 caps
                  Re: r540 samsung
                  it looks way smaller with smaller pads ten usual toshiba big token. i dont think he can solder 4x330d on it
                    Re: r540 samsung
                    can i used nec/tokin 0E128?
                      Re: r540 samsung
                      lol
                      read this
                      https://www.badcaps.net/forum/showth...t=toshiba+lock
                      same problem!
                        Re: r540 samsung
                        No, as they degrade quite a bit when being soldered thru normal methods. You'll have the same problem soon. Just use regular tantalum caps.
