Toshiba Satellite c850 display
  • angel-boy
    • 550
    • Romania
    Re: Toshiba Satellite c850 display
    I have a bios L855, same problem , no image intern or extern, i try bios, i make reballing to ati 216-0810028, i change the cpu, .....nothing !!! caps lock and num working.
    remains reballing all memorys, or SLJ8E ( BD82HM76 )
    • angel-boy
      • 550
      • Romania
      ANY help ?
      • gcomputers
        • Apr 2013
        • 509
        • Albania
        Maybe HM76 need to be replaced?
        • MDY
          • Jan 2014
          • 75
          • Spain
          Anybody found the solution for these Toshiba L855?
          • FShahid
            • Nov 2012
            • 57
            • United Kingdom
            Maybe northbridge chipset needs reflow or replacing.
            • bilinch
              • May 2015
              • 19
              • Turkey
              #26
              I also change northbridge, nothing change. The machine is still in the same condition as i said in my old post.
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                #27
                i have same problem to... board CAPS and NUM working, bios flash no change...
                reflow vga or pch = same, no effect
                any info on problem?
                Im Back... sort of...
                • ghass
                  • Apr 2014
                  • 45
                  • lebanon
                  #28
                  hi i think it is gpu rams even you replace the vga chip will not work it is the gpu rams chips
                  • nassimhamdi
                    • Feb 2016
                    • 149
                    • algeria
                    #29
                    But where is nuvoton npce and bq
                    • nassimhamdi
                      • Feb 2016
                      • 149
                      • algeria
                      #30
                      reball gpu or change it
                      • pravin6p
                        • Mar 2014
                        • 75
                        • india
                        #31
                        cccccccc
                        • pravin6p
                          • Mar 2014
                          • 75
                          • india
                          #32
                          does anyone rectified the no display problem for toshiba C850 ?
                          • pravin6p
                            • Mar 2014
                            • 75
                            • india
                            #33
                            hi,
                            i solved the issue its with amd gpu
                            changed the amd 216-0810028 GPU WITH AMD 216-0833000.
                            NOW ITS WORKING FINE.
                            • alibisma
                              • Oct 2014
                              • 37
                              • Saudia
                              #34
                              enable the UEFI Boot use the external 100% ok
                              • leggat2000
                                • May 2016
                                • 7
                                • AlgĆ©rie
                                #35
                                try to enable uma mode (it disable amd gpu and activate intel hd video )
                                just search uma in schematic and you will see components hat shall be enabled and disabled
                                • dirigjenti29
                                  • Apr 2018
                                  • 20
                                  • alb
                                  #36
                                  do you have schematic how to enable mode uma c855 or any link tutorial?
                                  • dirigjenti29
                                    • Apr 2018
                                    • 20
                                    • alb
                                    #37
                                    Forget about it. You cannot do that. There is an uma version without discrete graphics. The discrete version is builded without processor igp power rail. Lvds connector gets its signals directly from dgpu...etc. There is no way to convert it to uma
                                    • Kiop
                                      • Nov 2018
                                      • 28
                                      • France
                                      #38
                                      Thanks for the tip , it was my next step ... so not worth it ...
                                      • ghaleb
                                        • May 2019
                                        • Jordan
                                        #39
                                        Originally posted by dj_ricoh
                                        cook the whole board!
                                        hi,
                                        if motherboard is not damaged..which coil we can remove to convert discrete to integrated?
                                        i have the same motherboard which was sent by innocentforeign.
                                        thanks
                                        • Claudiomfa
                                          • Nov 2015
                                          • 455
                                          • Portugal
                                          #40
                                          Originally posted by ghaleb
                                          hi,
                                          thanks
                                          That board can“t be converted from dsc(discrete) to uma. Missing some components to activate the integrated vga.
                                          Do vga chip reballing or change a new one
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite C850 C855 Laptop Schematic
                                            6050A2509701-MB-A03
                                            C855D-S5104
                                            C855D-S5340...
                                            11-01-2024, 04:38 AM
                                            Toshiba Satellite Pro Satellite Pro A30-D-10E Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A30-D-10E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A30-D-10E boardview and Satellite Pro A30-D-10E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:35 AM
