dell latitude 3330 no video at lvds. works fine on vga. the screen definitely works as i tried it another laptop. any pointers?
 Re: dell latitude 3330 no video at lvds
 Here is a typical data sheetAttached FilesComment
 Thank you all for the help but i gave up on this. Pins at lvds are too close to each other and extremely hard to test. Even strapping a needle to my test probe didn't help. I still can't find a datasheet for it and the one cyberhack posted doesn't quite match up.Comment
 I know you have given up, the data sheet was just to give you a start how lvds work.i use a bench microscope not that model but close to it.
 http://www.prlog.org/10561190-mantis...microscope.jpgLast edited by cyberhack; 08-09-2014, 03:40 AM.Comment
 I'm in the process of buying a scope also. Even though i give up on stuff i always ask myself "why did i fail?" and "what can i do to help if i meet this problem again?" and the answer was a bench microscope. thanks for the suggestion.Comment
 Did you test the lvds cable for continuity . i hear what you say about small pins
 but doesnt matter as much if they are not powered - perhaps faulted at the kink between main body and screen?
 Any fuses on boards at either ends?Please upload pictures using attachment function when ask for help on the repair
 http://www.badcaps.net/forum/showthread.php?t=39740Comment
 i tested with a screen and cable that i know works. i got both from another working laptop. didn't see any fuses.
 it is almost funny how helpful this community is. even after i've given up and said let it die i still continue to get helpful suggestions. nice environment here Last edited by LiquidCap; 08-09-2014, 02:52 PM. Last edited by LiquidCap; 08-09-2014, 02:52 PM.Comment
			by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
 Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
 Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
 Pictures of these boards:
 Dell Latitude 5520 https://www.ebay.com/itm/256052956663
 Dell Latitude 5530 https://www.ebay.com/itm/125844181534
 Dell...4 Photos
			by Chivo77hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
 1- After receiving power SIO_SLP_S0# goes high and never changes.
 2-every...07-03-2025, 09:20 AM
			by F R 2568Hello all,
 this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
 I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
 If the laptop is only connected to the AC adapter (battery removed):
 When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
 The power/battery...
			by YOUCEF4787Hello everyone,
 I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
 Initial Problem:
 The laptop was completely dead, no signs of life, no power LED.
 Action Taken:
 I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
 Current Situation & The Main Issue:
 The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
			This specification for the DELL Latitude 3580 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3580 boardview and 3580 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3580...09-06-2024, 07:05 AM
- Loading...
