Help Identifying IC on MacBooks Pro - 820-02020
  • Digital Solutions
    • Jun 2025
    • 8
    • Sri Lanka
    Subject: Help Identifying IC on 820-02020 (MacBook Pro A2338 M1, 2020) — C02045500 / EKQ8LL1A
    I'm working on a MacBook Pro A2338 M1 (2020) with logic board 820-02020.
    The machine has a power issue — not powering on, and I'm trying to trace the fault.
    While inspecting the board, I found a cluster of components
    This area looks damaged or burned — there are about 4–5 components that seem affected
    I've attached a close-up photo of the chip and its surrounding area (see below). I'd like to know:
    • What is the function of this chip?
    • What is the reference designator on the board (e.g., U0500)?
    • Is it a known power rail/PMIC/USB-C controller?
    • Any known common failure points or related measurements I should check?
    There's obvious visible damage or corrosion,
    Any insight from those familiar with M1 boards would be hugely appreciated.
    Thanks in advance for your help!
    Photos/Videos:
  • Digital Solutions
    • Jun 2025
    • 8
    • Sri Lanka
    Bump
    • martyjelen
      • Mar 2023
      • 127
      • Czech republic
      UR600. I think it's speaker amplifier
      • Digital Solutions
        • Jun 2025
        • 8
        • Sri Lanka
        Thank you so much martyjelen for the info! Really appreciate you taking the time to help.
        Just one quick question, do you think only UR600 is likely defective, or could the other surrounding components (some of which look slightly discolored) also be affected?
        I want to be sure before ordering or replacing parts.
        Thanks again for your insight!
        • martyjelen
          • Mar 2023
          • 127
          • Czech republic
          One cap near amp looks burned to me. But maybe I'm wrong. Better test it.
          • Digital Solutions
            • Jun 2025
            • 8
            • Sri Lanka
            Thanks for the reply.
            • Digital Solutions
              • Jun 2025
              • 8
              • Sri Lanka
              Bump
              • Sephir0th
                • Oct 2020
                • 1249
                Originally posted by Digital Solutions
                Bump
                Why? The main part of your questions was already answered with the screenshot of the schematics containing the TAS5770AC0 in Post #5
                FairRepair on YouTube
                • todordm
                  Macbook A2338 / A2337 - Replace SSD
                  by todordm
                  There are a lot of Video Tutorials how the SSD of A2338 or A2337 can be upgraded. Normally they say you can order the bigger SSD chips (0 and 1) from China. But as far as I understand you can take the SSD chips of one A2337/A2338 and install on another, put to DFU mode, do the recovery, reinstall etc... I tried that several times (tried to upgrade 256GB to 512Gb, then to 1TB, then to another 256Gb)... nothing worked. So my question to the community is: can I just take the SSD chips from one A2338 and intall them on another A2338 (taking care of course of the 0 and 1 positions)? Or I have always...
                  01-17-2024, 03:55 AM
                • User555111
                  A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                  by User555111
                  Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                  02-05-2024, 08:16 AM
                • jkruns
                  Macbook Pro M1 A2338 - how to test for 20V?
                  by jkruns
                  I have a stack of liquid damaged A2338's, most of which don't draw more than 5v and thus won't turn on.
                  So far I've put back the main boards back after cleaning and repair attempts and connected every single component before testing. This obviously take a huge amount of time.
                  My question is (maybe not limited to A2338 boards): what's the bare minimum that needs to be connected in order to test if it will draw 20V? Should it draw 20V without the battery connected?
                  10-18-2024, 10:38 AM
                • jkruns
                  M1 A2338 screen and touchbar issues after cleaning up liquid damage
                  by jkruns
                  This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                  My patient is an A2338 Macbook Pro M1 (late 2020).
                  It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                  04-22-2024, 06:45 AM
                • classicandy
                  MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
                  by classicandy
                  Hi Everyone,
                  Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
                  UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
                  04-14-2024, 12:00 PM
