MBP A2289 board 820-01987 Bad U3200?
  • abajor
    • 175
    Just looking for a second opinions before I try to source a CD3217
    Rear USBC sits at 5.1V 0.01A
    Forward USBC power cycles.
    PPBUS_G3H 7.5-8.3V cycles with rear USB, Cycles 0-12.5V on forward USBC
    PP3v3_G3H_RTC ~3.9V with rear USBC, cycles 0-5.1 on forward USBC.
    PP3v3_UPC_XB_LDO diode drop reads about 0.074V
    I'm almost positive it's U3200 (its also the only thing getting warm on thermal camera) second opinions always helpful.
    Thanks!
  • mon2
    • Dec 2019
    • 14238
    If U3200 is heating up, remove all power. Meter in resistance mode. Measure the resistance to ground of each and every power rail linked to this device. Someone is shorted and causing an excessive load which is resulting in heat.
    PP3v3_UPC_XB_LDO diode measurement looks bad. Red to ground; black on this rail?
    Confirm it in resistance mode. What is the resistance in ohms? Someone at the output is shorted here.
    • abajor
      • 175
      Both directions read the same! Measuring from c3208.
      • mon2
        • Dec 2019
        • 14238
        How many ohms? Appears to be shorted.
        • abajor
          • 175
          Sorry running around trying to do too much stuff
          about 37 Ohms
          • mon2
            • Dec 2019
            • 14238
            Flux and remove C3208. Test if the resistance to ground changes to a normal range. If not, U3200 is very likely to be defective. Flux and remove U3200 to confirm.
            • abajor
              • 175
              U3200 definitely the culprit reading 1Mohm without it.
              Now I'm assuming I must source a CD3217 which is flashed for an a2289 in the U3200 position?
              • mon2
                • Dec 2019
                • 14238
                Yes, unless proven otherwise, use devices from a donor board and from the same position for the replacement parts.
                https://boards.rossmanngroup.com/thr...turn-on.64472/
                Be 100% sure to source parts with the same markings as the original. Do request donor parts from the same position due to the OTP (one time programmable) firmware embedded inside each such power delivery controller.
                Update this thread with your results and vendor you use for this sourcing.
                • abajor
                  • 175
                  The search thus far is not great. Plenty of stuff on AliExpress which claim compatible with my model, but no indication of which U3XXX position. If I find A vendor I'll update, might just need to buy donors in hopes of finding a good one.
                  • mon2
                    • Dec 2019
                    • 14238
                    Ask the vendors for advice. Perhaps they will know more. Reach out to Mobile Sentrix in VA. Could not find much from their site but they do sell the controllers. Post a topside pic of the CD3217 you have onboard. From other posts, the location; part number and origin of the parts do matter.
                    ipetro has experience on this topic.
                    • abajor
                      • 175
                      The Terrible U3200
                      ipetro
                      • abajor
                        • 175
                        The CD3217 is conspicuously absent from their site.
                        • mon2
                          • Dec 2019
                          • 14238
                          Following vendor just chatted to say the locations do not matter on A2289 repair. The parts are from original board and have been reballed. Just solder in to repair.
                          I just found this on AliExpress: US $4.47 | CD3217 CD3217B12 Chip for Macbook Pro A2159 A2289 A2179 A2337 A2338 A2141 A2442 A2485 A2251 A2442 Motherboard Repair IC Chipset
                          https://a.aliexpress.com/_mOhFIA7​
                          chat with them to confirm before purchasing. Do note your A2288 board.
                          • abajor
                            • 175
                            Hmmm interesting, from what I've read one of the issues is many of the bigger mac pro's like the A2141 they flash an I2C address into a one time flashable rom, I'm sure there's other things flashed into the room too. I will give a try and report back. I might have a doner if location truly doesn't matter.
                            • abajor
                              • 175
                              mon2
                              I just picked up a CD3217 from Amazon which claims to be compatible with my unit. I've improved in that U3200 is no longer shorted on the LDO regs, it's not heating up. The jack that feeds U3200 power cycles. The Jack that powers U3100 stays at 5.2V .4A. My power up sequence stops at P5VG3S_EN staying low.
                              I have one more CD3217 which I can try from an identical board from the U3100 position. I may try swapping it if there aren't other things I need to check for P5VG3S_EN staying low.
                              • mon2
                                • Dec 2019
                                • 14238
                                Try a DFU.
                                https://repair.wiki/w/MacBook_Air_A1..._signal_repair
                                • abajor
                                  • 175
                                  Do you think the unit will DFU when the jack corresponding to U3200 (The forward most one) power cycles?
                                  To answer that question it's not detecting in apple configurator.
                                  The only other thing I see on thermal is the U6903 buck converter is active and warmish under thermal. Output voltage at the inductors is 3.3V
                                  • abajor
                                    • 175
                                    I ended up buying a liquid damaged A2289. After ultrasonic cleaning and replacing and reflowing some passive components I could see that both USBC connectors would request 20V from my Power supply, stabilize for a few seconds then reboot.
                                    Instead of searching that problem I chose to harvest the U3200 CD3217 and put it on the customer machine.
                                    I saw that both ports were requesting 20V after the swap so I put it back together.
                                    The laptop boots right up; however, only the U3100 USBC jack powers up and charges the laptop. The U3200 USBC causes my inline power meter to rapidly strobe on an off.
                                    After a PRAM reset it appears to work in one position. But one rotation of the USBC jack causes a slow on off strobing on my power meter.
                                    I don't currently have the password to test the laptop further but confirmed that the Donor most be from an identical model and position for the A2289.
                                    • abajor
                                      A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
                                      by abajor
                                      Like title says A2141 came in with Water Damage, customer desperately wants the data.
                                      The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
                                      I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
                                      That said after cleaning up the...
                                      12-21-2024, 07:16 PM
                                    • rilley
                                      MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                                      by rilley
                                      I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                                      I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                                      My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                                      And the resistor L4004 is literally burned.
                                      From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                                      07-10-2024, 01:57 AM
                                    • drscoot
                                      usbc connector replacement on mobile
                                      by drscoot
                                      I replaced the broken usbc connector on this Ciontek CS50 mobile device. It worked fine afterwards, although it looks like the battery went down quickly and the device got warm at the back (battery section). After putting it in standby for a while it didn't came back anymore?
                                      The battery is still charging (red led), but no power on.
                                      I had another look at the usbc connector, it looks like one of the components is melted down (blue marking)? I have a picture of an untouched device and then the repaired device with 2 pictures; what are these components with B1 and PB marking? Are these...
                                      07-13-2025, 02:37 PM
                                    • edugimeno
                                      (old) LG 32lk330 cycles Backlight 3 times and then OFF
                                      by edugimeno
                                      Hi!! I have been given this old TV set.
                                      When I hit the power button, the BL (as you know this is a CFL backlight) turns on, video works fine as I can see the LG logo show off, but the backlight starts going on-off for 3 times, when it gives up and turns completly off
                                      This set has a inverter board on the top right corner. This inverter (or the tubes, I don't really know) buzzes very loudly during the second that the BL stays ON. I have posted a video, turn your volume UP!
                                      https://fileport.io/9EdfmD5qtEaw
                                      I have checked voltages at the PS
                                      All normal voltages...
                                      12-11-2023, 01:28 PM
                                    • nikolayu
                                      Lenovo ThinkPad X1 Nano Gen 1 not charging on 1 USBC
                                      by nikolayu
                                      I have Lenovo ThinkPad X1 Nano Gen 1 which is not charging on 1 usbc port (the one that has mark for charging).
                                      When i connect usb it switchs to 20v but no current draw (only 0.02a) and orang light is on. In windows it shows that is charging but percentage is dropping.
                                      Other usbc is charging fine,
                                      I installed lates bios and firmwares for thunderbolt and battery.
                                      Could be faulty JHL8040R controller?
                                      08-31-2024, 11:08 AM
