What model is this HP mini?
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Hello guys, I got HP mini here which I cannot confirm model. Upon researching it seems to be an HP mini 210 but I need to confirm this. There's no model on laptop or I might be misreading it. Problem is no light from dc jack. Might be bios. If someone have schematic and bios file please share. Thanks very much
    Check images.
  • trebo
    • 514
    • Wales, UK
    Re: What model is this HP mini?
    when you enter the part number from your first pic into ebay, you get, HP Mini 110-3000 *** 647048-001 *** Integrated 1.66 Intel Laptop Motherboard
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      Yes you're right but as soon as I browse further it becomes 210. I think I need to remove it from case to check processor. thanks man
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Hi - I tried under HSTNN-F05C which suggests 210
        but on hp forum it says HSTNN-F05C is not a model or part number
        I did spot a video and when they removed the back panel from a 210HD
        there are some white labels on the underside. does yours have any are they any help?
        • lezsimply
          The Wanderer
          • 645
          • Philippines
          processor is Intel atom N570 1.667Ghz dual core, memory is ddr3. I also find this code please check image again. Thanks.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            http://elektrotanya.com/hp_mini_210_.../download.html
            • trebo
              • 514
              • Wales, UK
              take a look at this, first and second post in particular, same motherboard code, https://www.badcaps.net/forum/showthread.php?t=26108
              • lezsimply
                The Wanderer
                • 645
                • Philippines
                Thanks very much guys. I have finally found the model no. Its an HP Mini 110-3715TU. The owner told me he put an electrical tape on the side of the sim card slot to make the battery fit. It was my mistake not to notice, but it was a clean cut. As if it was made from the factory. It took me almost 5 hours to figure it out, how stupid of me. Well now at least we can focus on the main problem of having no power.
                • lezsimply
                  The Wanderer
                  • 645
                  • Philippines
                  cleaned whole board with alcohol. dc jack now have light but when power button is pressed its gone. need to replug the adapter again to see dc jack light. I've got bios from hp but don't know it will work. I'll try tomorrow and see if it would help
                  • lezsimply
                    The Wanderer
                    • 645
                    • Philippines
                    Got bios files from hp from the exact model but its different in size. Does this bios need to be modified first?
                    • lezsimply
                      The Wanderer
                      • 645
                      • Philippines
                      still looking for schematic or bios file, many thanks!
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        Did you get to this page?
                        http://h10025.www1.hp.com/ewfrf/wc/p...00804&sw_lang=
                        • lezsimply
                          The Wanderer
                          • 645
                          • Philippines
                          I didn't get there but I've downloaded version F.25. I have extracted .fd from it but size is different and when I load it on my programmer its different from the stock one. I think it needs to be modified first.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            Did owner have it from new? was the bios on any support disks
                            • lezsimply
                              The Wanderer
                              • 645
                              • Philippines
                              Yes its new, first owner. I talked to the owner awhile ago. and I think its not a bios issue. She told me they left house to go on shopping around 8am, she forgot to unplug laptop from socket. She arrived home 5pm. She remove adapter from socket and used laptop for about an hour. then it suddenly turned off. When pressing power button the dc jack led indicator goes off.
                              I checked laptop for short but didn't find any. No heating components. Its hard for me to test further because I don't have schematic yet. I hope someone has...
                              • SteveNielsen
                                Retired Tech
                                • Jun 2012
                                • 2327
                                Does it power on with ac only and the battery removed?
                                • lezsimply
                                  The Wanderer
                                  • 645
                                  • Philippines
                                  I'm doing this, only ac is attached, with battery there's no response. 5v and 3.3v are present and steady. power button also have 3.3v
                                  • SteveNielsen
                                    Retired Tech
                                    • Jun 2012
                                    • 2327
                                    Perhaps you've got a bad battery then or the contacts aren't making good connections. You mentioned the owner having to use a piece of tape to make the battery fit.
                                    • lezsimply
                                      The Wanderer
                                      • 645
                                      • Philippines
                                      I think battery is ok, according to owner last at least 2 hours. there a problem I think on power rails. There maybe short somewhere. Need to find schematics first. Thanks guys.
                                      • fddizon
                                        • Sep 2011
                                        • 555
                                        • Philippines
                                        try reflowing SIO chip
                                          HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:27 AM
                                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        • roshon
                                          does anybody have Schematic and board view Mac Mini 2018 model A1993 MLB 820-00939-A - does not boot,
                                          by roshon
                                          does anybody have Schematic and board view Mac Mini 2018 model A1993 MLB 820-00939-A - does not boot, ...
                                          05-09-2024, 10:06 AM
