MacBook A1990 — No Display With Battery Connected
  • mavaro
    • May 2017
    • 28
    • Polska
    Hi, I have a problem with MACBOOK A1990 - The laptop starts with no image when the battery is connected, but without the battery it starts with an image - however, when using only the power supply, when logging into the system it turns off and resets again.
    Battery replaced with another unit → same problem.
    ISL9239 replaced → no change.
    SMBUS_BATT_SCL / SDA measure ~20-50kΩ to GND with battery disconnected (normal).
    Any ideas or advice would be a huge help!
    Thanks in advance for your time.​
  • mon2
    • 14086
    What is the voltage to ground of the following with the battery connected?
    SMBUS_3V3_BATT_SCL
    SMBUS_3V3_BATT_SDA
    PPBUS_G3H
    with battery?
    • mavaro
      • May 2017
      • 28
      • Polska
      I don't know how it happened, but it only works on battery. Maybe it required an SMC reset. After starting it up and entering passwords, it freezes and the touchbar doesn't light up.
      • mon2
        • 14086
        Try a DFU.
        • mavaro
          • May 2017
          • 28
          • Polska
          I don't have a second MacBook. Is there an option without additional hardware?
          • mon2
            • 14086
            Post # 2.
            • mavaro
              • May 2017
              • 28
              • Polska
              Originally posted by mon2
              Post # 2.
              PPBUS_G3H - 12V
              SMBUS_3V3_BATT_SCL - 3.3V
              SMBUS_3V3_BATT_SDA
              - 3.3V
              Macbook is behaving strangely. When it's hot, it starts up without a picture, but after a while it cools down, the picture appears - but when I try to log in, it hangs.
              • mon2
                • 14086
                Test with an external monitor. The SMBUS voltages are fine - they are not shorted.
                • mavaro
                  • May 2017
                  • 28
                  • Polska
                  External monitor is working. Even though the battery is disconnected, the settings after starting show the information: battery fully charged and service recommended status.
                  • mon2
                    • 14086
                    Backlight fault?
                    Test with a torch / flashlight to the front face of the display. Display is defective? Was the unit dropped? Post pics.
                    Does the caps lock led toggle ok?
                    • mavaro
                      • May 2017
                      • 28
                      • Polska
                      Backlight fault?
                      The image works without the battery, with the battery too, but then the laptop hangs. Apple diagnostics hangs on error code: PFM006
                      • mon2
                        • 14086
                        Run ASD for a deeper dive.
                        https://boards.rossmanngroup.com/thr...nostics.12917/
                        • CornholioGSM
                          Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
                          by CornholioGSM
                          I have here one interesting problem.
                          Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
                          I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
                          Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
                          06-25-2024, 12:27 PM
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • platinumsteel
                          Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
                          by platinumsteel
                          Hi guys i have a 820-00840 that works fine and boots up as long a battery is not connected. I initially thought it was a bad battery so i went ahead and bought a new battery for it and slapped it in yesterday and realize that the same fault exists. When i screw in the battery and connect the little battery strip and i press the power button it will not power on.At that time If i connect the charger i get fan spin for 10 seconds then stops but the machine won't power on.If i disconnect the little battery strip and re-plug the charger the machine boots as normal.It's not the battery connector strip...
                          03-03-2023, 10:17 AM
                        • code share
                          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                          by code share
                          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                          Here's what I've tried so far:
                          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                          • Booted successfully on AC power only with the battery disconnected
                          • Visual inspection of the battery — no swelling, burn marks, or connector damage
                          • Battery
                          04-21-2025, 12:50 PM
                        • survivalbloke
                          Acer Predator Helios 300 - will not power up if battery is CONNECTED
                          by survivalbloke
                          This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                          06-25-2025, 12:20 PM
